Lifting tacoma questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blacktaco902, Oct 8, 2020.
  1. Oct 8, 2020 at 7:58 AM
    Blacktaco902
    Blacktaco902 [OP] New Member
    2015 Tacoma SR5
    So I plan on lifting my truck problem is I have covered parking. The lowest point is 78" the current highest point of my truck is the back rack which is 71 3/4. I planned on 3" in the front and 2" in the back. Also plan on going up to 285 75 16 from my 245 75 16. Am I going to be completely screwed?
  2. Oct 8, 2020 at 8:55 AM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    You will probably be ok, but yeah it will be close. Going from a 245 to 285 you are ROUGHLY going from a 30” tire to a 33” tire which means you will only gain ~1.5” in vehicle height from just the tires, so keep that in mind. Add in the lift kit and I bet you will be good.
    Why 3” lift?
    Are you aware that you should definitely get aftermarket UCA’s?
    Are you ready to trim and chop fender and liners in order to fit 285’s?
  3. Oct 8, 2020 at 9:02 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    Do the math. Looks to me like you should clear it by about two inches. You might want a shorter antenna. Mine catches hell in parking garages.
  4. Oct 8, 2020 at 9:09 AM
    15TACOSPORT4X4
    Stan
    I went 3" and 285's five years ago and still using factory UCA's. -12 offset 18" wheel and cut NOTHING. I took a heat gun to the plastic liner on both corners and rolled it back just a little and no rub at all.
  5. Oct 8, 2020 at 9:17 AM
    Blacktaco902
    2015 Tacoma SR5
    Through my sketchy math I figured I'd be good. Already swapped the antenna out a few years ago it rubbed going in then
    15TACOSPORT4X4 likes this.
  6. Oct 8, 2020 at 1:55 PM
    Blacktaco902
    2015 Tacoma SR5
    Anyone ever run into problems after lift and level. Vibration? Pros and cons?
