Lifting techniques that won't cost an arm/leg
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Mar 26, 2017.
  1. Mar 26, 2017 at 8:45 AM
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    I'm in the market for a relatively inexpensive lift kit for my 17 OR DCSB. \
    While I do have some background in car mods, this is my first truck and therefore the first vehicle I will lift. I am looking for a way to increase ground clearance by around 3". Definitely looking to purchase a set of 32-33" KO2's but to my understanding, the truck will definitely need to be lifted first.
    I found a couple of "spacer lift" kits on Amazon for relatively cheap. This one in particular looks to be the most useful: https://www.amazon.com/gp/product/B00IOYRF6G/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
    Will I be able to keep the factory bilsteins? To my understanding, this will increase ground clearance everywhere except for the rear diff. Will I need a wheel/steering alignment after the lift? Any advice or tips would be greatly appreciated. Thanks.
  2. Mar 26, 2017 at 8:49 AM
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    You'd be better off spending a little extra on front coils, add-a-leaf in the rear, and some inexpensive shocks! Spacers and lift blocks aren't good if you want to actually to wheel, I'm sure some people disagree but You could do a quality 2-3" lift for about $650, if that's in the budget!
  3. Mar 26, 2017 at 8:51 AM
    JFick
    Los Angeles
    vprgts and HeadStrong Off-Road like this.
  4. Mar 26, 2017 at 8:52 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Welcome, if you didnt know TW has a search option. Lift kits, tire sizes, clearance issues, etc have been covered quite a bit. You should be able to find what you are looking for. Enjoy your new truck..
    paradox4286, uhplifted and JFick like this.
  5. Mar 26, 2017 at 8:54 AM
    JFick
    Los Angeles
    ^great idea as well
  6. Mar 26, 2017 at 8:55 AM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    I'm in South Florida, so most of my wheeling is through sandy, sometimes bumpy trails. No rocks or anything crazy down here. 99% of the time I don't even need 4x4. $650 isn't all too bad, though since I am looking to purchase everything at once.. adding around $800 for tires, and $700 for wheels puts me in the neighborhood of around $2,200 :facepalm:
  7. Mar 26, 2017 at 8:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Never understood why someone would go out and spend in the above $30,000.00 price range for a truck and throw such a pile of shit lift on it. Research research research, and Buy Once and Cry Once.
  8. Mar 26, 2017 at 8:57 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Any time you mess with anything relating to your suspension you will need an alignment. Also keep in mind that the only true way to lift your truck is to add bigger tires. If you go with 33's you are adding 1" of ground clearance as compared to stock.
    JFick and Unchained 5150 like this.
  9. Mar 26, 2017 at 8:58 AM
    JFick
    Los Angeles
    Go get a lifetime alignment plan from a reputable chain. I got one for $70...
    Unchained 5150 likes this.
  10. Mar 26, 2017 at 8:59 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    I highly doubt ANYONE on here would disagree to the statement I bolded for you.
  11. Mar 26, 2017 at 9:00 AM
    JFick
    Los Angeles
    The bro truck 2WD gang would beg to disagree :puke:
  12. Mar 26, 2017 at 9:04 AM
    uhplifted
    Brian
    16 DCLB OR
    Well they're wrong.
  13. Mar 26, 2017 at 9:05 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Just put these in the front.
  14. Mar 26, 2017 at 9:06 AM
    JFick
    Los Angeles
  15. Mar 26, 2017 at 9:06 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    And these in the back.
  16. Mar 26, 2017 at 9:15 AM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Use your legs, not your back :benchpress:
    ...oh wait. :frusty:
  17. Mar 26, 2017 at 9:16 AM
    JFick
    Los Angeles
    The key is to stack blocks!
  18. Mar 26, 2017 at 9:18 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I will. Depending on what you want, for the rear small lift blocks are sometimes a good option. For the front, forget it. Then again, forget 1/2 the expensive crap I've seen put of the front of these trucks on this forum IMO.
    Problem you have with overly arched springs is, for the same travel the axle will actually move backwards a greater distance than with a less arched spring. That makes the compression part of the travel soft and the rebound part of the travel really hard. Not really an issue for slow rock crawling, but sucks on the road and anything fast offroad. Also make shock valving a real pain to get right. The other problem you get is because the axle is moving back as well as up, it gives you less tire clearance against the fender.
    Again this all depends on what stock springs are like and how high a lift you want to go, there are loads of factors to consider, I personally wouldn't just "assume" lift blocks are crap in every situation.
    20tacoma17 likes this.
  19. Mar 26, 2017 at 11:51 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    PM Sent :D
    :wave: Hope you guys are having a good weekend :cheers:
  20. Mar 26, 2017 at 11:54 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Gotta help out our Vendor of The Year whenever we can
