lifting the rear and need help
Discussion in 'Suspension' started by yotatoy, Dec 11, 2012.
  1. Dec 11, 2012 at 9:08 PM
    yotatoy
    yotatoy [OP] Well-Known Member
    il
    2010 Toyota TRD 4x4 4D V6
    Avid side steps Nokia Yellow fog lights t-rex eyelids trd sport hood front windows tint
    i wanted to ask, if anyone knows,
    if i lift the rear 1in to 1.5in
    any other parts will i need other then the blocks or add a leaf
    any help would help even were to buy the rear kit
    thanks
  2. Dec 13, 2012 at 6:40 PM
    yotatoy
    il
    its a 2010 tacoma
    anyone
  3. Dec 14, 2012 at 10:12 AM
    OverRated
    OverRated Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    I recently did my rears and these are the parts I used.
    - 2x Bilsteins 5100 (Not required but is recommended)
    - 2x 1.5 AAL
    - 2x Center Pin (3/8 bolt & nut from a hardware store) or buy them on Toytec. (For sure this will need to be replaced)
    I would check out Toytec for your parts if you haven't yet.
  4. Dec 15, 2012 at 12:48 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This will work , get a couple grade 5 (or better) 3/8" shank bolts (preferrably threaded all the way) Knock the corners off (grind) & it'll drop into spring perch on axle nicely...
    OP, avoid using blocks if you can...
  5. Dec 15, 2012 at 4:07 PM
    Bookin
    Bookin Well-Known Member
    You'll need longer u bolts too. Toytec has those as well.
