lifting the rear with TSB
Discussion in 'Suspension' started by Larry, Oct 31, 2010.
  1. Oct 31, 2010 at 5:43 PM
    Larry
    Larry [OP] CARL
    CARL
    is the AAL the way to go?
    So, I'd end up with a 5 leaf pack?
  2. Oct 31, 2010 at 5:44 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yup. Unless you wanna completely replace the rear springs...AAL is much cheaper.
  3. Oct 31, 2010 at 5:46 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    AAL is the least expensive and easiest install that's worth doing.
  4. Oct 31, 2010 at 6:01 PM
    Larry
    Larry [OP] CARL
    CARL
    So...the TSB has netted me about 1" of lift.
    What would the AAL add? What options are there? 1/2"...1"...1-1/2"...?
  5. Oct 31, 2010 at 6:09 PM
    jandrews
    AALs typically come in 1.5, 2, and 3 inch varieties. TSB typically results in about 1.5" of lift. I went with a 1.5" AAL on my TSB'd truck and it ended up with about a 1" rake after lifting the front 3".
    Your call...I'd say 1.5 to 2" leaf.
  6. Nov 1, 2010 at 4:51 AM
    michaelg589
    michaelg589 Well-Known Member
    Just installed my AAL kit. I added it to my non-TSB springs. So inow have 4 leafs. It raised my truck at least 1.5" proabably more like 2. It has a serious rake now. I need Some OME springs and Bilstein 5100s :)
  7. Nov 1, 2010 at 7:09 AM
    Larry
    Larry [OP] CARL
    CARL
    My TSB 4 leaf pack raised the rear 1.5" at the start about a month ago...it has settled into about 1" with use.
  8. Nov 1, 2010 at 7:48 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2, the TSB will live you about 1" of lift after settling.
  9. Nov 1, 2010 at 8:25 AM
    TacomaGRG
    TacomaGRG Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    So what do you guys recommend setting the front 5100s at with the rear tsb
    I just want it to look some what level. A slight rake is ok.
  10. Nov 1, 2010 at 8:47 AM
    KPT
    09 Prerunner
    1.75"
  11. Nov 1, 2010 at 9:05 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    :drool:
  12. Nov 1, 2010 at 9:06 AM
    KPT
    09 Prerunner
    Thx :D
  13. Nov 1, 2010 at 9:10 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks! and thanks for the pic thats the stance I want.
  14. Nov 1, 2010 at 9:11 AM
    ScottyKC
    ScottyKC Well-Known Member
    Scott
    Omaha
    08 Tacoma Sport SR5
    Bilstein 5100 set to 2.5" lift in front. Rear TSB with 1.5" rough country. Bridgestone Dueller Revo2 265/70/17 Satoshi mod, and painted center caps, tinted windows.
    How is the ride after AAL install?
  15. Nov 1, 2010 at 9:16 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    ??? Why did you do this? The rear already sits higher than the front from the factory, and now another 2"?? I can't understand why you would lift the rear without the front...I'm confused...
  16. Nov 3, 2010 at 5:07 PM
    2K6 Taco
    2K6 Taco Well-Known Member
    Philly
    06 TRD Sport D-Cab LG Bed
    is the AAL mainly for lifts or is it capable of handling loads?
  17. Nov 3, 2010 at 5:11 PM
    jandrews
    Lift height, load capacity is affected by a hella of a lot more than the leaf springs, not least of which is the frame.
    If you want greater loads capacity, you can get some custom made Deaver or Alcan packs that will bump you a couple hundred pounds, but you're looking at 6 or 700 bucks for 'em, plus install if you're not willing to do it yourself.
  18. Nov 4, 2010 at 1:58 PM
    2K6 Taco
    Philly
    thats too much for capacity. i have the TSB springs but thought that if i add another leaf to the 4 packs, it'd bump up the capacity a bit.
  19. Nov 4, 2010 at 5:38 PM
    jandrews
    You *might* be able to get some AALs custom bent by Deaver, Alcan, et al that would add some capacity, but it'd likely be more pricey than your standard AAL due to the custom engineering needed.
  20. Nov 4, 2010 at 9:27 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I think he is talking about adding front OME coils and billies .
