Lifting the rear
Discussion in 'Suspension' started by MrWortWort, Feb 15, 2023.
  1. Feb 15, 2023 at 10:42 AM
    MrWortWort
    MrWortWort [OP] Well-Known Member
    2021 SR Access Cab Tacoma
    I'm planning to lift my truck to 2.5 in the front and I want to lift to rear to match the height
    So do I a add a leaf on the stock leaf for now?
    I'm planning to to buy a new leaf pack in the future once I get a rear steel bumper and skid plates
    I'm asking for cost reasons and if there's any good add a leaf brands out there
  2. Feb 15, 2023 at 10:49 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I did same in the front but went with one-inch blocks in the rear and taller shocks. I have about 150K on this set up and it has worked well for me. I off-road but mostly in the dez. Get steel blocks if you go this route, not alum, and you will need longer u-bolts. The braked lines are long enough but I did put a half-inch spacer where it bolts to the axle.
  3. Feb 15, 2023 at 10:52 AM
    MrWortWort
    What brand did you get?
    I heard allot of negative things about getting blocks to lift the rear
  4. Feb 15, 2023 at 11:20 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Maxtrac blocks. Forgot to add, I also have the carrier bearing drop kit. It is basically a thick washer (about 1/2 inch) with longer bolts. You'd want that for any lift anyways, not just for blocks. The biggest con is axle wrap, but more so on 2-inch + blocks. The risk is minimal on one-inchers. Same with blown u-joints. I replaced my oem's with Spicer u-joints at about 80K; truck just passed 200K with those Spicer u-joints. And that is with standard grade non-greasable u-joints. Spicer offers a more robust u-joint but I don't feel I need them for my usage.
