Lifting to fit 285/75/16
Discussion in 'Suspension' started by Pistolpete88, Apr 20, 2020.
  1. Apr 20, 2020 at 1:34 PM
    Pistolpete88
    Pistolpete88 [OP] New Member
    Great Barrington Massachusetts
    2017 Toyota Tacoma TRD Pro
    Hello,
    I have a 2017 Tacoma TRD Pro, I’m looking to lift it to fit 285/75/16. I’m having trouble finding a 1-1.5” lift, does anyone have any suggestions?
  2. Apr 20, 2020 at 1:35 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    3rd Gen 2019 Cement DCLB TRD OR
    265/75r/16 Ko2 / Bird nest engine bay.../ 6112/5160/ med pack
  3. Apr 20, 2020 at 1:37 PM
    JaCado
    JaCado Bad luck charm
  4. Apr 20, 2020 at 1:52 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    itsmermf likes this.
  5. Apr 20, 2020 at 2:12 PM
    vecdran
    vecdran Barely-Known Member
    Seattle, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
  6. Apr 20, 2020 at 2:16 PM
    hossler1788
    hossler1788 Well-Known Member
    Josh
    jonestown pa
    2016 taco trdor
    you can fit 285 75 16 on a stock pro, you might have to trim and maybe a cmc, Id much rather do that then adding spacers.
  7. Apr 20, 2020 at 2:17 PM
    mds08
    mds08 Senior member
    Parts Unknown
    2018 Silver Sky double cab longbed
    Oh no, don't put a spacer lift on it. That's all everyone says when they want to lift a truck a few inches. But since it's a Pro it's okay.
    71tattooguy likes this.
  8. Apr 20, 2020 at 2:18 PM
    Pistolpete88
    I called headstrong off road this they suggested 1/2 in spacer that wood give 1 in of lift and a 1 in block is that going to be enough to fit 33 or 285 and dont get how 1/2 spacer give 1 in of lift
  9. Apr 20, 2020 at 2:37 PM
    Pistolpete88
    Will 1/2in spacers that give 1 in of lift and 1 in blocks will I be able to fit 33 or 285 ?
  10. Apr 20, 2020 at 2:39 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, King Shocks, TC UCA, Full set of Skids, Pirrelli's, Air-bags, ARB locker, BAMF hangers and more +++.
    Do lots more research, there's alot more to lifting these trucks than just installing a set of coilovers or spacers. Good luck with your truck
    whatstcp likes this.
  11. Apr 20, 2020 at 2:40 PM
    whatstcp
    whatstcp Professional incoherent spammer
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    whatever the spacer thickness, double it for the amount of lift it should provide.
    And to fit 33s (and especially dirtyfives) it's more about chopping, fuckton caster, trimming, and bashing (35s)
    Mully likes this.
  12. Apr 20, 2020 at 2:40 PM
    Mully
    CA
    Welcome to TW Brother.
  13. Apr 20, 2020 at 2:40 PM
    rnish
    rnish Well-Known Member
    Maryland USA
    Tacoma 2nd gen
    Pro Suspension (Bilstein), OME Dakar (med), armor
    Go to forums: plenty of info in “suspension”, also “wheels and tires”.
  14. Apr 20, 2020 at 2:43 PM
    Pistolpete88
    Thanks still trying to Figure all this outI’ll take any suggestions on what lift or suggestions on what I should do to fit 285s under the truck comfortably with minimal rub
  15. Apr 20, 2020 at 3:24 PM
    mds08
    mds08 Senior member
    Parts Unknown
    Everyone is always against spacers as it will cause all kinds of issues, compresses the springs and cause your ride to suffer. You cannot trust everything you hear. Also some say you can fit the 285s with no lift. Good luck, best bet is to try a reputable 4wd center in your area to make it work.
    Pistolpete88 [OP] likes this.
  16. Apr 20, 2020 at 3:29 PM
    vecdran
    Seattle, WA
    Or, you know, opens up the possibility of snapping the entire damper in half.
  17. Apr 20, 2020 at 3:34 PM
    msgs350
    msgs350 Well-Known Member
    M
    Renton WA
    2020 Tacoma OR Cement DCSB 4x4 AT
    Who keeps track of the days? Everyday is like a Friday!
  18. Apr 21, 2020 at 3:34 AM
    Proudad103
    Proudad103 Active Member
    Steven
    Boyertown, PA
    2019 Super White TRD PRO
  19. Apr 21, 2020 at 3:54 AM
    bludweiaer
    pa
    2017 Pro DBL Cab
    thanks for the OK .. lol
  20. Apr 21, 2020 at 4:00 AM
    bludweiaer
    pa
    2017 Pro DBL Cab
    i think you want alittle more in the front so its level,, my pro used to have a 3/4 in rake... now its more like an inch. rake,, with my 1 1/2 front spacer, i wont have to have the coils dissasembled, my spacer goes on top, i should have 1/2 in. or less of rake with the 1 inch rear block.. and the 1 1/2 in strut spacer. hoping to not have any issues with this small lift, its just for looks.
