Lifting = trim??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raycie, May 2, 2010.
  1. May 2, 2010 at 5:09 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    I would have thought that lifting the truck a little bit would save the need to have to trim..
    Changed tires to 265/70/17 on the stock 17" sport rims. No problem at all..
    Installed bilstein 5100s @ 1.75, and the tires started rubbing on the inside of the mudflap. It was rubbing on that small bump area on the inside. (not even sure why they made a bump there instead of being perfectly flat.
    Of course I needed to have the wheel turned perfectly 1/2 way and enter my driveway, or go over a speedbump, but obvisouly I met with the "perfect" conditions more than a couple of times since installing the bilsteins..
    Fixed that with the help of a heavy duty box blade, but still baffled why no prob with the larger tires, but rub with the tires and a small lift..
    Anyone similar?
  2. May 2, 2010 at 5:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    The mud flaps sit just a hairs width inside the fender wells....When you lifted the truck that part got higher in relation to the tire- and lined up with the thickest part of the tire and started rubbing.
    If you aren't rubbing on your cab mount or the fenders- I wouldn't worry about it. These mudflaps kinda suck anyways.
  3. May 2, 2010 at 5:17 PM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    hmm.. got it.. so basically that "bump" usually sits lower than the "3'oclock" of the tire.. by lifting, I raised the bump to "3 oclock".. thanks.. makes sense..
    Yea.. just got irritating to hear that scraping sound every once and awhile.. Made me flash back to the 'ol days of a lowered rice burner..
  4. May 2, 2010 at 5:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah..I gotta find someone local to me to chop and box my cab mounts...cause the noise that makes is bugging me. I feel your pain!!
  5. May 2, 2010 at 5:30 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Planning on going 2.5" when I lift. Switching to a wheel with an 1.25 inch less backspacing (but 1 inch wider), ditching the mudflaps. Hoping I can get 33s in there with only minor trimming.
