Lifting truck without changing stock grill & TSS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jondoeski, Apr 2, 2021.
  1. Apr 2, 2021 at 9:08 AM
    jondoeski
    jondoeski [OP] Active Member
    2021 TRD SPORT DCLB
    Question is for those who have lifted their newer Tacomas with TSS (safety sense) and did not change out the grille with modified sensor. Curious to hear how it affects the TSS. Does it still work to some degree?
    MountainManGuy likes this.
  2. Apr 2, 2021 at 10:23 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Worked perfectly fine for me after lift, and continues to work after lift and pro grille.
  3. Apr 2, 2021 at 10:32 AM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Technically, if you added a pro grill, you actually lowered the position of the TSS sensor and placed it closer to the stock position.
    OP asked for those who did not swap out the stock grill.
  4. Apr 2, 2021 at 10:33 AM
    renlo
    I added a 1.5” leveling kit and have stock grill. No problems at all.
    jondoeski[QUOTED][OP] likes this.
  5. Apr 2, 2021 at 12:05 PM
    TurdTaco64
    Brandon
    Fort Collins
    That's true but my point was that after my lift with the stock grille it worked fine. And by saying it continues to work fine after the pro grille I mean they aren't as finicky in my experience as some people think.
    jondoeski[OP] likes this.
  6. Apr 2, 2021 at 12:12 PM
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    We have been lifting trucks for a little while and installing pro grilles for even longer than that. We have not been able to notice a difference in behavior in either our own truck or from reports from customers. The truth is that in most situations the radar has a wide enough viewing angle so that it will still see any vehicles in front of you even if the angle changes a bit. Imagine that the sensor was calibrated for only a very specific range... what would happen if you were to load your taco's bed with gear and effectively change the angle of the sensor? Toyota has to account for that, it is built into the software to compensate for slight variations in attitude.
    EDIT: Disclaimer... a friend of a friend told me that... :anonymous:
