Lifts and UCA's Confused!!!
Discussion in 'Suspension' started by B11, Jan 23, 2013.
  1. Jan 23, 2013 at 12:49 PM
    B11
    B11 [OP] Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    Seems as though there is a lot of confusion/misinformation regarding the need for new aftermarket upper control arms when you lift your Tacoma.
    I've got a 13 Taco dbl cab TRD OR that I have been researching lift/s information on pretty much since I bought it about a month ago. The vast majority of everything I read said when you go over 2.5 inches of lift you need to also get new UCA's or you Taco won't align properly and it will drive bad and or wear the tires out.
    I just seconds ago got of the phone with ICON Vehicle Dynamics and he told me UCA's were NOT needed for the lift height, 2.75-3.0 inches, I was looking at. The ICON tech I talked too said I would have NO problem getting my alignment, caster, camber, etc., set properly with their lift in the range I was looking for.
    For my needs the ICON Stage 1 with their AAL's would be perfect and I could easily get the 2.75-3.0 inches of lift I needed to clear the 255/85/16 or 255/80/17 KM2's.
    He did say that if I was looking to seriously off road my Taco that then he would maybe recommend the UCA's as it would give me more range of motion but in the lift height that I'm looking at that would pretty much be the only reason I would want to replace the factory UCA's.
    I truly appreciated his honesty because he could have easily said I needed them and sold me something I didn't need. Instead, he saved me about $800. When I get ready to order my lift, it will definitely be an ICON lift.
  2. Jan 23, 2013 at 12:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's all fine and well but he's incorrect about he need for UCAs at that lift height. You will be hard pressed to get a proper alignment with that lift with your stock UCAs. As far as range of motion, unless you're going with an extended travel shock, you aren't getting any additional range of motion with aftermarket UCAs. You can only go from full stuff to full droop, the UCA isn't limiting you therefore the UCA isn't going to give you any additional range of motion.
    Talk to someone like Downsouth Motorsports.
  3. Jan 23, 2013 at 12:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    " in factory spec " is a pretty broad range
    Just sayin
  4. Jan 23, 2013 at 1:00 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    2.5" of lift is about the threshhold. if you stay at or below 2.5" you can get a good alignment. however, if you go above 2.5" and especially at 3" you will need new UCA's to get a proper alignment.
  5. Jan 23, 2013 at 1:04 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    You can run stock arms I did when I had my procomp3 in lift if your only gunna do street queen/mall crawling you'll be fine but if you plan on offroading I would definetly recommend after market uppers
  6. Jan 23, 2013 at 1:08 PM
    Pugga
    Massachusetts
    I find stock uppers being more of a problem on the road since it causes the truck to wander at speed. Could be an issue for high speed off roaders.
  7. Jan 23, 2013 at 1:14 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd play it safe and get aftermarket UCA's.
  8. Jan 23, 2013 at 1:22 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If you don't think that you need UCA's then you definitely don't need to spend $800 on icon UCAs, there is options for half of that. I agree with everyone else, play it safe and get UCA's. especially if you are willing to spend that much on coilovers
  9. Jan 23, 2013 at 1:27 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Man those "Techs" at Icon sure know everything don't they :D
  10. Jan 23, 2013 at 1:35 PM
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    One note that has been mentioned on the multitude of other threads on this (I know, a lot to read through) is that each truck tends to be slightly different. My experience on my 2011 DCSB TRD OR TX:
    OME w/885 coils required new UCA's
    I had my alignment done 3 times with stock UCA's and it would be just within spec and 5 days later, way out of spec.
    Added Light Racing UCA (Neutral position)
    Alignment done and it was pretty much perfect, 6 months of driving and it stayed there.
    Every truck is going to be slightly different, you can try to run the lift without new UCA's, but check your alignment more than once.
  11. Jan 23, 2013 at 1:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^^
    They might be able to get the alignment "In spec", however, thats secs for a NON lifted truck. The alignment specs change when lifted, and need to be more precisley set, and at certain amounts of Caster/Camber.
  12. Jan 23, 2013 at 1:46 PM
    trd2011
    trd2011 Well-Known Member
    Jacob
    Mississippi
    '15 TRD Sport
    Sportsman camo seat covers, 265/70R17 Kumho MT's, 20% Tint, 5000K HIDs
    I just installed Eibachs with 5100's set @ .85 and the 2" AAL. I got 2.5" of lift in the front. My toe and camber alignment is good but the caster is a little off, which makes it a little darty. I've been driving 70mph+ and it doesn't seem bad at all to me. Said all that to say, I don't believe you can get a proper alignment with stock UCA's if you go the full 3".
  13. Jan 23, 2013 at 1:47 PM
    RedYoter10
    RedYoter10 Well-Known Member
    Andrew
    Clifton, Maine
    10 4x4 access cab 2.7
    Bilstein 5100's, 265/75/16's, LCE header.
    I'm only running the 5100's in front at 1 3/4" up and they say that I am bordering the end of my alignment range... I am definitely considering the light racing uca's. As they have said, every truck is different, but that's my experience.
  14. Jan 23, 2013 at 5:50 PM
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    Now you all can see why my title said confused. :rolleyes:
    I'm actually not a big fan of how it drives in stock form right now. As it sits stock it feels to me like it needs more positive caster. I think it lacks directional stability and doesn't track forward all that great. If lifting it makes this worse because it loses positive caster I will gladly put ICON UCA's in when I lift it.
    I'll call Downsouth Motorsports tomorrow and report back with what they have to say. Thanks for the tip on them, Pugga.
    I want to be one and done when I do this. Last thing I want is to pull it apart multiple times.
  15. Jan 23, 2013 at 6:00 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Ran 2.5" of lift with stock UCAs for 6 months and regretted lifting my truck everytime I drove it (1.2* caster). Bought and installed LR UCAs...got 3* of caster and it drives great now.
  16. Jan 23, 2013 at 6:07 PM
    tsup74
    tsup74 Well-Known Member
    Alberta
    2013 Tacoma Double Cab
    Extang Solid Fold, pop and lock
    I'd rather spend the extra 450-700$ Max and do it right the first time. I own the same thing, 2013 Double Cab and after spending almost 40K for the truck, what's another bit of cash to do it properly. JMO
  17. Jan 23, 2013 at 6:35 PM
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    tsup74, I see you're from Alberta. Very close to Banff or Lake Louise area???
  18. Jan 24, 2013 at 12:59 PM
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    Talked to Downsouth Motorsports today and here is what they had 2 say.
    Like many here, they definitely feel the UCA's are a good idea, especially, if you are creeping up on 3 inches of lift and you want it to drive well.
    Sooooo, it sounds like I'm going to go with ICON lift w/AAL and rear canister shocks, doing canister shocks because I don't really like emulsion shocks, and I'm going to use Total Chaos UCA's because the Downsouth Tech thought the ball joint Total Chaos uses was a little better product than the ball joint ICON uses.
    Thanks for any and all help, appreciate it!
  19. Feb 7, 2013 at 5:43 PM
    tsup74
    Alberta
    Live in Calgary, about an hours drive to Banff.
