Lifts and waranties
Discussion in 'Suspension' started by MapMasterG, Nov 15, 2006.
  1. Feb 25, 2007 at 5:25 PM
    #41
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    Yup as long as what ever I'm going under hits less than about three inches of the antenna, I'm good to go.
  2. Oct 29, 2007 at 1:00 PM
    #42
    Rmorris
    Rmorris New Member
    07 Tacoma SR5
    None
    The correct answer on voided warranties was cited by Banshee. The law requires that the manufacturer prove causation before it can just void a warranty. Many dealers still try (at least once) to decline warranty claims of any kind, if a vehicle is lifted or otherwise altered. However, the law is quite clear that for them to do so, they must prove a connection between the modification, and the damage. That's the answer, and its written in stone. Accordingly, if you have any reputable company install a reputable mod, you should either be covered by the warranty on the mod, or the warranty on the vehicle...they can't both disclaim liability. Good luck.
  3. Jan 31, 2010 at 11:54 AM
    #43
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    3 inch Revteck will not void the warrenty because it is not messing with the origional suspension components it is just compressing the spring my Uncle put the 3 on and his warrenty is still good.
