Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TaCoTuEsDaY16, Mar 9, 2019.
  1. Mar 9, 2019 at 12:09 PM
    TaCoTuEsDaY16
    TaCoTuEsDaY16 [OP] Well-Known Member
    Adam
    Louisiana
    2018 Tacoma TRD off-road 4x4 DCSB
    Recommendations for lifts taller than 3”
  2. Mar 9, 2019 at 12:12 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You’re limited to only a few brands if you go more the 3” fab tech is one of them.
  3. Mar 9, 2019 at 12:19 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    Thank you I’ll check it out
  4. Mar 9, 2019 at 12:21 PM
    tcjacado
    tcjacado Well-Known Member
    You are looking at drop bracket lifts for above 3 inches on 4wd and spindle lift if 2wd for 4+ inches
  5. Mar 9, 2019 at 12:22 PM
    My Name is Rahl
    @KTJO 4x4 has a 6" lift. Check out her build thread.
    El Duderino and tcjacado like this.
  6. Mar 9, 2019 at 2:27 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    That truck looks sick
  7. Mar 12, 2019 at 1:34 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    With 888 springs 5100’s and Dakar md leaf pack would it be okay to run stock wheel/tires till i upgrade?
  8. Mar 12, 2019 at 2:19 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I wouldn't consider any lift over 3 inches an "upgrade". The 888 springs, 5100s and Dakars will be good for most instances.
    1.5-3 inches is the sweet spot for performance and capability, anything higher you're just raising the center of gravity to make your truck more top heavy but not gaining much clearance. 6 inches of fender height will not gain clearance of the differentials.
    Tires bigger than 33 inches will need a re-gear.
    tcjacado and BlueFalconActual like this.
  9. Mar 12, 2019 at 2:36 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    So the 888 and 5100’s the way to go?
    tcjacado likes this.
  10. Mar 12, 2019 at 2:37 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yessir! You might need aftermarket UCAs for a decent alignment but it's better than a 6 inch lift performance wise.
    My truck with a 2 inch lift (887 springs with 3 leaf AAL) and 265/70/17 tires.
    SilverII likes this.
  11. Mar 12, 2019 at 3:02 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    What’s the difference between the three leaf and Dakar pack?
  12. Mar 12, 2019 at 3:05 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Lookswise about the same, performance wise the Dakar can handle more weight.
  13. Mar 12, 2019 at 3:59 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    So if i have a overland rack and tent i should do Dakar or is that not a lot of weight like your talking?
  14. Mar 12, 2019 at 4:06 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What's the weight of that and will it be a permanent feature of the truck? If yes and over 200lbs all the time then an aftermarket full leafpack like a Dakar.
    I have 150lbs in my toobox but it's close to the cab so the AAL is fine.
    El Duderino likes this.
  15. Mar 12, 2019 at 4:38 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    The rack and tent is 220 together but not a permanent thing. The rack would be more than the tent and it’s only 100lbs
  16. Mar 12, 2019 at 5:55 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Stick with the Dakar in the rear.
  17. Mar 12, 2019 at 8:07 PM
    TaCoTuEsDaY16
    Adam
    Louisiana
    Any uca suggestions?
  18. Mar 12, 2019 at 8:43 PM
    El Duderino
    Jeremy
    HI->PNW
    JBA or SPC can’t go wrong with either from what I read. I’m running Total Chaos but if I wasn’t it would be running JBA
    tcjacado and jsinnard like this.
  19. Mar 13, 2019 at 2:14 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I have SPC, happy with all the adjustability but can be confusing for some alignment shops.
    Only reason I skipped the JBA is the red color.
  20. Mar 13, 2019 at 3:10 AM
    TaCoTuEsDaY16
    Adam
    Louisiana
    Anything else needed to help support the truck with this lift?
