Lifts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vic toyota, Apr 10, 2024.
  1. Apr 10, 2024 at 5:03 AM
    Vic toyota
    Vic toyota [OP] Member
    3 1/2 rough country lift 285/70/17 tires -6mm offset
    Hello,
    I am new to this. I have a 2022 Toyota Tacoma TRD off road. I put a 3.5 lift on it, new tires that have been balanced and an alignment done. I am have been dealing with a shaking at interstate speeds that I can’t get rid of. Any ideas as to why? Can’t seem to figure it out. Any help would be great. Thanks.
  2. Apr 10, 2024 at 5:05 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    New wheels? What lift kit?
  3. Apr 10, 2024 at 5:06 AM
    Vic toyota
    Falken wildpeaks 285/70/17 with -6mm offset. With rough country 3.5 lift
  4. Apr 10, 2024 at 5:43 AM
    Vic toyota
    Also just wondering, if I went back to my a stock set up with a 2inch spacer in the front what wheel offset can you go with if I were to keep 285/70/17 tires? Or would those tires not even fit that
  5. Apr 10, 2024 at 6:20 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Try looking up carrier bearing spacer. 3.5" is a lot for suspension lift in my opinion. A lot of the angles are out of whack. Goodluck
    RIX TUX and MR E30 like this.
  6. Apr 10, 2024 at 6:22 AM
    Vic toyota
    Yeah I’m thinking about just dropping it back down to stock with 2inch . Do you think 285s would fit?
  7. Apr 10, 2024 at 6:34 AM
    Big Cole
    Big Cole Well-Known Member
    Do you feel the shaking in the steering wheel or floorboards?
  8. Apr 10, 2024 at 6:34 AM
    Vic toyota
  9. Apr 10, 2024 at 8:10 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    2” lifts IMO. Keeping components happy and cv’s not touching fins.
  10. Apr 10, 2024 at 8:18 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    yeah, many here stay under 2" of lift for these and other reasons. Also, RC isn't one of the lifts held in high regard.
    RIX TUX and Mark77 like this.
  11. Apr 10, 2024 at 8:27 AM
    Vic toyota
    So just to clarify if I sent back to stock high with a 2inch level spacer in front, would it fit 285/70/17 with -6 offset? And if not, what should I get that would clear
  12. Apr 10, 2024 at 11:36 AM
    Vic toyota
    Also by any chance that when the truck was lifted it make the driveshaft sit at a weird angle to cause vibration? Would a carrier bearing drop kit help?
  13. Apr 10, 2024 at 12:34 PM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP-Photos help us see/understand your predicament, also post your alignment printout if you have it.
    Rough Country lift-is this a Drop Bracket kit? Rough country is known for being an aesthetic only lift, no performance enhancement(they ride like dump trucks bc of the drop bracket, so id say its a loss)
    ECGS bushing is highly recommended for any lifted taco, esp above 2” lift(factory bearing is known to fail and cause “high frequency” vibrations)
    Wheels/tires- 285s will fit on a 2” lift WITH a frame mount chop, some fender massaging, and a proper alignment.
    The main issue with lifting a IFS vehicle above 2” is all driveline angles, you’ll chase your tail trying to fix a issue that is created by the lift.
    RIX TUX, Mark77 and Chew like this.
  14. Apr 10, 2024 at 12:53 PM
    Vic toyota
    I will take some pictures later. also what if I downsized to 265/70/17 tires with-6mm offset would I be safe with that?
  15. Apr 10, 2024 at 12:57 PM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    You can run 265/75/16 on a stock taco without issue, idk why/if a 17in rim would make a difference but it should be similar. 285s require more “work” bc of UCA clearance, frame mount clearance issues, and having to massage fenders if utilizing the truck offroad(for actual clearance).
  16. Apr 10, 2024 at 1:07 PM
    Vic toyota
    I gotcha. I was just trying to salvage part of this build because I’ll need to get new tires but was going to try and keep the 17inch rims. Would the -6mm offset give any issues?
  17. Apr 10, 2024 at 1:13 PM
    Vic toyota
    And yes rough country has this drop kit if you have a two part driveshaft
  18. Apr 10, 2024 at 1:16 PM
    Wisky57
    Wisky57 Well-Known Member
    2021 Army Green Toyota Tacoma TRD Off-Road
    I have those size tires with a 3in lift. No problems yet.
  19. Apr 10, 2024 at 1:32 PM
    Mark77
    Mark
    Nothing yet
    Anyone mwntion the front diff drop spacers?
    My lift is 3 inches. Toytec up from and custom alcan springs in the back. Never had a vibration. What wheels and tires are you currently running? Who did the mount and balance? So.etimes tires can be finicky and need to be road force balanced.
  20. Apr 10, 2024 at 1:53 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why do you need a lift?
