light affordable lift,tires, wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tac.rod, Aug 15, 2013.
  1. Aug 15, 2013 at 11:56 AM
    Tac.rod
    Tac.rod [OP] Member
    Costa mesa
    06 tacoma 2.7 sr5
    K&n filter
    any recommendations on good affordable lift kits ? I want to throw some 265/70/17 or so on my truck. the lighter the better since I only have a 4cyl and don't want to lose too much power
  2. Aug 15, 2013 at 11:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Check out toytectlifts.com.....stay away from spacer lifts.
  3. Aug 15, 2013 at 12:07 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For tires, stay with P265/70R17 to help save weight. They'll still be plenty strong enough to support any weight the Tacoma is rated to tow/haul but weigh less than LT tires.
    For a lift, can't go wrong with the OME kit or a spindle lift if you're 4x2.
  4. Aug 15, 2013 at 12:11 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Light lift? Do you mean you want just a small lift? If that's the case, eibach coils for 2nd gens only provide 1.5" of lift. If your wanting 3"s then go OME or spindal lift if your a PreRunner.
  5. Aug 15, 2013 at 7:54 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    you can run that size without a lift, stay with a p metric to save weight. i am assuming you are 4wd. i ran Toytec 3" with aal for over 7 years with no problems, the one with 885 coils but i am 4wd dblcab.
  6. Aug 16, 2013 at 10:05 AM
    Tac.rod
    Tac.rod [OP] Member
    Costa mesa
    06 tacoma 2.7 sr5
    K&n filter
    Thanks for a the replys, The truck is a 2wd and it is not a PreRunner. I would preffer not to spend more than 2,000 for tires, wheels, lift
  7. Aug 16, 2013 at 10:23 AM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    What are you trying to achieve that you could not get by buying a PreRunner?
