Light bar in lower valence
Discussion in '1st Gen. Tacomas (1995-2004)' started by ocaldwell332, Sep 28, 2016.
  1. Sep 28, 2016 at 8:04 AM
    ocaldwell332
    ocaldwell332 [OP] Well-Known Member
    Owen
    2004 Silver Tacoma V6 PreRunner
    So I see a lot of tacomas on here with 30 inch lightbars in their lower bumper valence. When I took it to get installed yesterday they said it wouldn't fit. Anybody have a write up or suggestions for making it fit. If not I have a lightbar for sale lol.
  2. Sep 28, 2016 at 8:17 AM
    dtd608
    dtd608 Well-Known Member
    Aiken, SC
    '13 Tacoma TRD Off Road
  3. Sep 28, 2016 at 8:18 AM
    ocaldwell332
    Owen
  4. Sep 28, 2016 at 8:19 AM
    dtd608
    Aiken, SC
    Oh ok. Idk I'm sure you'd have to do some cutting/trimming. Good luck though!
  5. Sep 28, 2016 at 8:21 AM
    ocaldwell332
    Owen
    Probably will. Thanks!
  6. Sep 28, 2016 at 9:17 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    no matter what you're going to have to cut the valence a bit if you want it in the valence. You can cut the center fin and fit a 20" bar between the next two, but you're going to want to look for a 1row, not 2 row bar. (searching for "slim" usually gets you more hits for those)
    you can put a 30" back there, but the valence will cover a bit of the lights, and you'll have to technically mount it behind the valence so that it shoots through it. you then also don't have to cut any of those little fins, but...they'll be in front of the light.
  7. Sep 28, 2016 at 10:13 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    I've been looking into this to... I'm not sure how to do it just yet... But I know it's possible to mount it behind it and it looks very nice
  8. Sep 28, 2016 at 10:17 AM
    TooMuchToDo
    ...we'll get there.
    grab some L brackets and a drill, the width part is easy just space them appropriately for the light bar you buy and mark the holes on the crush bars (bars behind your bumper). the height you'll need to measure from the crush bar to the hole in your valence. you'll probably need to drill some extra holes in the L bracket to make that line up correctly
  9. Sep 28, 2016 at 10:20 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    There is an aluminum crash bar behind the valance, you can screw the light bar mounts I to that; or attach a piece of angle iron to the crash bar, and the light to that.
    I used the latter method. It lets you install without cutting any of the valance. I don't have any pictures of the bracket handy, but can get some if you want.
  10. Sep 28, 2016 at 10:22 AM
    TooMuchToDo
    ...we'll get there.
  11. Sep 28, 2016 at 11:00 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    bling useless IMO
    that tupper ware up front cannot support chit
    and any lights mounted will likely vibrate
    Unless a substructure support is built.
    Not to mention the tupperware is usually destroyed /or boogered
    when ya start bumping into things (ie: earth).
  12. Sep 28, 2016 at 2:04 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    there is a metal bar/structure right behind the plastic on the lower part but you would still have to drill the plastic.
    but you also have a point, if the LED bar is "in" or " in front" of the valance it will be the first thing to go :D
  13. Sep 28, 2016 at 4:40 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I'm fully aware of what is behind that tupperware...
    as I have removed and discarded mine long ago.
    The metal support behind it is simply there to hold it in place.
    and is designed to crumple - flex at 5mph.
    and is barely strong enough to support the load
    of the tupperware facia itself.
    In other words... it's not really a bumper
    just a plastic facia to offer a finished look.
  14. Sep 28, 2016 at 7:56 PM
    TooMuchToDo
    ...we'll get there.
    up to op to decide what approach to take. If he's taking long jumps and ripping up crazy trails... do something more substantial. Wanna light up a camp site or a dark road, simpler will do it.
