Light bar install in Lower Grill Opening
Discussion in 'Lighting' started by GTABurnout, Dec 1, 2012.
  1. Dec 1, 2012 at 2:54 PM
    GTABurnout
    GTABurnout [OP] Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    I ordered a light thru the okledlightbars.com GB. I went with a 20" because at the time I was planning on running a light bar. After some thinking I decided I would rather save the light bar money and mount it in the grill some how. I have no desire to change my actual grill so the next best spot is the lower Grill.
    So last night I pulled the grill and took a few measurements. And test fitted the light to see where i could mount it. I was hoping I could just mount it to the aluminum crash beam but the feet for the light would have made that too tall.
    The light:
    I noticed that the crash cans sit slightly below the crash beam. Unfortunately since I had a 20" light the feet would not span the 35" inches between the two. I decided to get a piece of angle iron and span the gap and then just mount the light to that.
    The angle iron would need to be 35" or more. I found a piece of 36" long 2"X1" L bracket.
    It would just need to be notched so the bracket would fit between the crash cans....
    Removing the bumper cover to get access to everything...
    Testing fitting the L bracket after cutting.
    Perfect....
    Now to see if the light will fit ok...
    And now to test fit the bumper to make sure my measurements where correct...
    Light fits correctly and is pretty much centered in the lower grill....
    Now I can not really access the locations where I want to bolt the L bracket to the crash beam. So Off it comes....
    Crash beam...
    Black painted Bracket...
    So the beam is pretty much a long piece of extrusion. So its hard to get bolts in and then get nuts on to those bolts. So I went with a few self tapping fasteners.
    I over did it. 4 on each side of the crash can and about 8 holding the loer part of the L to the crash beam.
    Center punches
    Bolted down and back on the truck.
    And bumper back on....
    With the bumper on I will need to remove the grill to gain access to the light but still I can re-aim if required.
    And all wired up.....
    All and all a successful install. The light bar is solid the mount is solid. Tonight I hope to meet us with another Tacoma who bought a 21S blitz pro light and mounted his in the same location with a different method and see how they compare.
    Night pics tomorrow.
  2. Dec 1, 2012 at 3:02 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Looks good. Can't wait to see night pics!
  3. Dec 1, 2012 at 3:17 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    very nice! how much?
  4. Dec 1, 2012 at 5:50 PM
    Glocker23
    Glocker23 Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Very cool. Want to come and do mine in CT ?
  5. Dec 1, 2012 at 5:55 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Awesome! Im' interested in the night pics and the light out put.
  6. Dec 1, 2012 at 5:57 PM
    LowHangingFuries
    LowHangingFuries Well-Known Member
    Dustin
    GA
    2009 TRD sport 4x4 sr5
    Lifted 3" with toytec coilovers and aal in rear. Xd wheels
    Man I like that truck too!
  7. Dec 1, 2012 at 6:45 PM
    60driver
    60driver Well-Known Member
    Sean
    CT
    10 DC TRD Sport 4x4 Tim Mica
    Illum 4x4 switch, 20" LED bar in lower grill, LED in scoop, aux fuse box, avid light bar and 'sliders'
    Nice work, unfortunately I have the pesky front license plate (damn you CT). Maybe I'll take it off until I move back home from wherever the army puts me. I would rather do it your way than a bolt on light bar. And I already have a 20" led sitting around.
  8. Dec 1, 2012 at 6:51 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Looks good. I was kicking around a 40" bar in the lower grill but not sure if it would affect the cooling.
  9. Dec 1, 2012 at 7:19 PM
    perchie15
    perchie15 Well-Known Member
    Joey
    Alberta
    TRD
    None,
    this is what i wanna do!! also a good way to avoid theft of the light by a little bit anyways :D
  10. Dec 1, 2012 at 7:50 PM
    GTABurnout
    Tucson AZ
    Plans are to get night pics tonight along with some pics of a Blitz Pro Bar mounted in the same location.
  11. Dec 2, 2012 at 12:24 AM
    Reeves
    Reeves Well-Known Member
    Colorado Springs, CO
    08 TRD Rugged Trail
    Is there any shake in the Light at night?
  12. Dec 2, 2012 at 7:03 AM
    SkullTaco2012
    SkullTaco2012 Well-Known Member
    2012 DC TRD Off Road
  13. Dec 2, 2012 at 7:04 AM
    Large
    Large Red
    Clean install. Any trouble aiming it while it's back there?
  14. Dec 2, 2012 at 8:05 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Eh... 40 is just a bit too big for there
  15. Dec 2, 2012 at 8:17 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nice writeup. Looks like a fine placement for a bar containing only spot/driving lights. I'd be worried that any "flood" bulbs would be impinged by the grill and have part of the "wide throw" light you look for with a flood cut off by the lower bumper.
  16. Dec 2, 2012 at 10:20 AM
    GTABurnout
    Tucson AZ
    I took the truck down a pretty rutted dirt road and the shake is no worse then the stock lights. Maybe tonight I will strap the GoPro and and take some video.
  17. Dec 2, 2012 at 10:25 AM
    GTABurnout
    Tucson AZ
    Night time Light Pics
    All pics taken with a D7000. Settings where manual and all pics taken with same settings. No photoshop except to resize.
    LED Bar Only
    Low Beams
    High Beams
    Highs and LED Bar
    TN_Tacoma and Dj Suisav like this.
  18. Dec 2, 2012 at 10:42 AM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    :thumbsup:
    Makes me want to buy one now........
  19. Dec 2, 2012 at 10:50 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    x2
    Super clean and sturdy mounting points.
  20. Dec 2, 2012 at 12:15 PM
    GTABurnout
    Tucson AZ
