Light bar install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chieffan2, Apr 8, 2011.
  1. Apr 8, 2011 at 5:45 PM
    chieffan2
    chieffan2 [OP] Member
    Los Angeles
    westin side steps, black grille, oem skid plate, Pioneer AVIC-Z1000 Nav
    Can someone help me. My Smittybilt street light bar just arrived with no install instructions. Does anyone have any? I believe it is the same light bar as the N Fab. I contacted both N Fab and Smittybilt but haven't heard back from them.
    Thanks
  2. Apr 8, 2011 at 6:34 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    Can you download some from their website? If not, try googling some.
  3. Apr 8, 2011 at 6:42 PM
    antatich
    antatich Well-Known Member
    Tony
    Bremen, Indiana
    2011 DC Silver Tacoma
    Ready lift SST w/ 2 inch blocks, 33x12.50R17 Dick Cepek Mud Country Tires, 1.25" Billet Spacers, Tinted Windows, DDM tuning HID Headlights and Foglights, N-Fab Side Bars, N-Fab Light Bar, 4 Hella 500FF, JL Amp, 12" shallow Mount Sub
    Get underneath the front and locate the frame forks. On the outside you will see two studs with nuts on the forks. Remove those nuts and set aside to use later. Find your light bar brackets and locate the slotted holes. Should be two on the short end of the bend. Put those brackets on the studs with the larger part against the fork. The triangle part should be at the top going towards the bottom grill. Once u put that on don't tighten the nuts all way. Repeat this for both sides. Then take you light bar and slide it through the grill. Take the four 10 mm bolts and nuts and put them through the holes. The square part of the nut goes through the slotted hole. Repeat for the other side. Then position the bar the way you want Nf tighten everything up! I just did mine last night! :)
  4. Apr 9, 2011 at 1:21 PM
    antatich
    Tony
    Bremen, Indiana
    Did that help you out? If you need I have the exact direction sheet because I just recited the last post from memory
  5. Apr 9, 2011 at 1:36 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    yep this is what u do!^^^ i did mine about a year ago but they sent me the same side mounting brakets (i was pissed) but i got extra long bolts for one side and its held up tighter than ever for a year now! good luck and put pics up
  6. Apr 9, 2011 at 11:22 PM
    chieffan2
    Los Angeles
    I am going to attempt the install tomorrow so I will let you know if I have any problems. Thanks for the info.
  7. Apr 10, 2011 at 12:52 AM
    tanzak88
    tanzak88 Well-Known Member
    Tanner
    BC, C-eh-N-eh-D-eh
    Its easy. Assemble it off the truck if you're that concerned about it. Mine only took about a half hour.
  8. Apr 13, 2011 at 2:44 PM
    chieffan2
    Los Angeles
    Thanks Guys. Install completed.
  9. Apr 13, 2011 at 5:26 PM
    Forewheel
    Forewheel Active Member
    Corpus Christi, TX
    '11 DC SB TRD Offroad
    Bone Stock.....for now.
    Looks good man! I think this might be one of my first mods.
