Light bar issues
Discussion in 'Lighting' started by NlOffRoad11, Feb 17, 2023.
  1. Feb 17, 2023 at 4:50 AM
    NlOffRoad11
    NlOffRoad11 [OP] Well-Known Member
    Tyler
    2021 Cement TRDOR
    Looking for some help to trouble shoot why my light bar isn’t working.
    I installed the bar with a typical on off 3 pin toggle switch and decided to replace it with a led light bar switch that has 5 pins.
    the light worked for about a month but now the switch doesn’t light up so the light bar isn’t turning on.
    Any ideas?
  2. Feb 17, 2023 at 4:57 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    What bar is it? Cheap bars will burn out pretty quick...
    Have you bench tested it to confirm if it's the light or the switch?
    Could just be a bad connection or ground.
    Bivouac and Shellshock like this.
  3. Feb 17, 2023 at 5:01 AM
    NlOffRoad11
    Tyler
    2021 Cement TRDOR
    it’s a good light bar (dura series) with full warrant.
    I haven’t tested nor do I know how to test for those issues
  4. Feb 18, 2023 at 8:58 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Never heard of a "dura series" bar. Do you have access to a test light or Digital Volt Meter (DVM) to test for ground and power? If you don't, since it's under warranty, I'd suggest getting back to the manufacturer.
  5. Feb 18, 2023 at 9:02 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You have a open circuit or the switch has failed.
    Do you have circuit protection is that open??
    A Multi meter and Code reader are 2 tools one should have to work on these vehicles
  6. Feb 18, 2023 at 1:58 PM
    NlOffRoad11
    Tyler
    2021 Cement TRDOR
    Yea I have a multi meter
  7. Feb 18, 2023 at 2:37 PM
    Too Stroked
    Tom
    Good! Start by checking for power and grounds - in that order. Sounds like you no longer have power going to the switch. Have you checked the fuse BTW?
  8. Feb 18, 2023 at 2:51 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I gotta ask a real dumb question.
    You're using a relay, right? You're not wiring the light bar directly to the switch, right?
    ZColorado and Bivouac like this.
  9. Feb 18, 2023 at 3:07 PM
    NlOffRoad11
    Tyler
    2021 Cement TRDOR
    Yes the fuse is good. I’ll check to see if there is power now! Thanks
  10. Feb 18, 2023 at 3:07 PM
    NlOffRoad11
    Tyler
    2021 Cement TRDOR
    Yep there is a relay
    Rock Lobster[QUOTED] likes this.
