Light bar
Discussion in 'Lighting' started by Tatum0806, Dec 5, 2016.
  1. Dec 5, 2016 at 3:19 PM
    Tatum0806
    Tatum0806 [OP] Well-Known Member
    Tate
    2005 silver Tacoma
    3" pro comp suspension lift 18x9 fuel hostages 33" Bfg ko2 Dual 10" kicker system
    Why does my light bar come on when my truck is off ?
  2. Dec 5, 2016 at 5:11 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    :goingcrazy:
    I'm thinking may need more info...:burp:
    How it's wired.. pictures...ect..
  3. Dec 5, 2016 at 7:26 PM
    Tatum0806
    Tate
    2005 silver Tacoma
    I was just wanting to know if it's suppose to always come on even when my keys aren't even in my truck or is it cause I have it wired that way ?
  4. Dec 5, 2016 at 9:39 PM
    override
    override Well-Known Member
    Robert
    2015 DC Tacoma Sport 4x4
    Umm if you wired it then shouldn't you know this question yourself? lol
    To answer you though, if you have the light bar wired direct from battery to relay to switch then your switch will be the only thing to manipulate the lightbar on/off. If you have the switch or relay wired so that when the key is off the 12v supply is killed then your light bar will turn off with the truck and also with the switch when the truck is running or key is to the acc/on position - pending how you wired it.
  5. Dec 5, 2016 at 9:51 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Does it come on by itself or only when you push the button? Either way, it means it is wired to 12v constant. So key on or key in the house, if the button is pushed it will turn on. Normal. However, if you mean you are sitting in your living room and the bar turns on, you have one of four problems.
    1. Your relay got water in it and the contacts are corroded and can randomly activate (common issue when people with aftermarket horn relays have them activate randomly).
    2. Someone is messing with you and flipping them on
    3. You have them wired to a remote controlled switch
    4. You have a ghost that likes to play jokes
    override likes this.
  6. Dec 5, 2016 at 9:54 PM
    override
    Robert
  7. Dec 5, 2016 at 9:56 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    :rofl:
    Oh boy...
    How do you have it wired???
    Did you tap into any existing wiring or use a harness that was included with it?
    We need to know and see pics to help you diagnose... :anonymous:
    :worthless:
  8. Dec 6, 2016 at 12:35 AM
    caribe makaira
    Caribbean, Puerto Rico
    You wired you LED to a circuit that is parallel to the gas leak check the vehicle does after shut down. The leak check test is random.
