Light engine rumble wheb idling after timing belt change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skratchmo007, Nov 17, 2015.
  1. Nov 17, 2015 at 7:41 AM
    Skratchmo007
    Skratchmo007 [OP] Member
    Stephen
    2002 Tacoma Prerunner 2wd 3.4L V6
    I have 264,000 miles on my Tacoma its a 2002 pre runner v6 3.4 liter and I just got the timing belt changed along with the water pump for the second time noticing there is a light engine rumble when idling every now and then. All new belts also put on. Something doesnt feel right. It never use to vibrate when idling. I can hear the vibration also from the way the exhaust sounds. Can anyone offer any insight?
  2. Nov 17, 2015 at 10:18 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    One cam may be a tooth off. Take it back to the mechanic.
  3. Nov 17, 2015 at 10:23 AM
    Skratchmo007
    Stephen
    Will do. Thanks!
  4. Nov 17, 2015 at 10:24 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Something is a tooth off.
  5. Nov 17, 2015 at 10:28 AM
    Skratchmo007
    Stephen
    Thank you.
  6. Nov 18, 2015 at 3:18 AM
    Skratchmo007
    Stephen
    Bringing it back to the mechanic tomorrow. I barely made over a bridge on my way home from work yesterday.
  7. Dec 5, 2015 at 10:47 AM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Hey OP, what was the fix? Did mine two weeks ago , so far everything is ok.
  8. Dec 5, 2015 at 10:48 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    This is why you do-it-yourself. Dont have to take it to anyone if something gets screwed up.
