Light off roading with non TRD 01 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by doctorbrad, Aug 22, 2010.
  1. Aug 22, 2010 at 11:22 AM
    doctorbrad
    doctorbrad [OP] New Member
    bradley
    seattle
    01 2.7liter 4X4 taco
    First post for me. Just bought 01 2.7 manual 4x4 sr5 taco with 90k in excellent shape, beautifully kept up by the second owner. Nice little truck, with no bells except A/C, rhinoliner, K & N cold air intake, and a nice tool box. It is NOT the TRD. I will have it in Mexico with mostly dirt roads, no major off roading high speed stuff just dirt roads around the beach with bunches of potholes. Is this baby up to the task?? How about more aggressive climbing off road stuff without the TRD? Also I read that the towing capacity is 3500 but the truck only weighs that much. I'll have a 2-3k pound trailer at most. Will it do ok pullijng that down the highway with the 4 cylinder? Anything else for a new taco owner about this truck I should know. I can see why people like these 4 cylinders, got some guts to it. thanks in advance
  2. Aug 22, 2010 at 11:49 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Any non 4x4 TRD is just as capable offroading Vs. a 4x4 TRD.
    As far as towing is concerned, I don't have much experience towing with a I4. But I have seen threads on here with guys asking the same question. And they do just fine, just don't go over your towing capacity.
    It may take a lot longer to get up to a good towing speed, and good MPG's will go out the door.
    Also would suggest putting an oil cooler on (TRD trucks have) if you plan on doing a lot of towing, or long distance/heavier loads.
    And make sure all your oil changes are up to date, and maintenance.
  3. Aug 22, 2010 at 12:07 PM
    doctorbrad
    bradley
    seattle
    thanks for your response, will definitely keep up on the maintenance, and my towing is only going to be rare
  4. Aug 22, 2010 at 1:04 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Light offroading you should be fine.
    Just yesterday I went out with a bunch of people from this site and did some offroading in my stock TRD 5spd. Bear in mind I haven't gone 4 wheeling before or used my truck for that, but man was I amazed at what it could do! We were climbed some pretty knarly steep/sandy hills and not once did I have to through it in low. In fact what got me the most was that I had it in 2wd 90% of time and probably could have done most all of it with it in there, but I did have it in 4x some of time for precautionary on the steep inclines. The thing just hooked up time and time again in 2wd even when going through the woops in the sandy wash pits and sliding around in the sand. I was really amazed. No, I have not done the grey wire mod so the locker was not engaged.I think the biggest down fall with a stock lift is ground clearence, but even then I did not scrape anything once the whole time.
  5. Aug 22, 2010 at 9:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The only thing your really missing is the rear locker.
    If you are conservative off pavement, you'll be fine. A more aggressive all-terrain type of tire will also help by giving you better traction in those iffy situations, those situations where having a rear locker makes up for a lack of traction.
