Light on dash is on?......
Discussion in 'Arizona' started by Coma2010, Jul 22, 2012.
  1. Jul 22, 2012 at 6:03 PM
    Coma2010
    Coma2010 [OP] 2012 TRD Off Road Prerunner
    Dustin
    Glendale
    2012 TRD PreRunner Dbl Cab
    I took my truck in for a oil change and tire rotation and then drove it about 60 miles running around town and now these lights are on. I know the check engine could be they did not reset it after oil change but for it to come on after worries me and the other light is making me wonder if I should even be driving it.....any help/advice would be nice.
  2. Jul 22, 2012 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the Check engine light is unrelated to an oil change reminder light.
  3. Jul 22, 2012 at 6:08 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Depending on where he took it, i wouldnt say its totally unrelated..
  4. Jul 22, 2012 at 6:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True. The dealer tech. could have changed the oil, by draining it, then hitting the ECU with a hammer.
  5. Jul 22, 2012 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ABS light would come one if the ABS sensor wa damaged. Not sure what would cause the tract light to be on.
  6. Jul 22, 2012 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    you and me both, Man.
  7. Jul 22, 2012 at 7:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Doesn't Trac/VSC come on with ABS and some CEL?
    Wife's Rav4 had a bum ECU (we're assuming, dealer never clarified, just swapped it after shotgunning for a week without resolution) and the VSC came on with the CEL.
  8. Jul 22, 2012 at 7:33 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Did fill up the gas tank recently, maybe that caps not tight.
  9. Jul 22, 2012 at 7:37 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    If I wasn't a member here, I'd have NO idea what dahell Rich just said. Thankyouuuu, TW!! :proposetoast:
  10. Jul 22, 2012 at 7:57 PM
    Coma2010
    Dustin
    Glendale
    I get the first part but what is the cel?
  11. Jul 22, 2012 at 8:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Check Engine Light.
    Your top light is NOT because they forgot to reset it after changing the oil.
    That light actually says "Maintenance Required".
    You have a problem that requires service from someone who knows WTF they're doing... not an oil change place.
  12. Jul 22, 2012 at 8:16 PM
    Coma2010
    Dustin
    Glendale
    Yeah good call on the Maint Requ light.
    Ahh ok check engine light...cel...
    I took the truck to Power Toyota in Chandler.
  13. Jul 22, 2012 at 8:19 PM
    Coma2010
    Dustin
    Glendale
    Nope I am the only one that puts gas in my truck although if my wife ever wanted to I wouldnt stop her :D
    Also I have ran through 3/4 of a tank when the oil change happened.
  14. Jul 22, 2012 at 8:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Double check the MAF and other connections on the air intake. Not sure what they may have gotten into if they removed the engine cover... shouldn't have been needed for the oil/filter change but it may have had to come off for the air filter service.
    I'd pull the cover and check anything that looks like an electrical connector. They had to have left something unplugged or knocked something loose.
    Double check and make sure the gas cap is on tight.
    But failing something obvious, I'd be back at the dealership tomorrow. Don't drive around all week with that CEL on... it could damage the catalytic if it's running lean, or it could decide to go into "limp home" mode and limit your RPM.
  15. Jul 23, 2012 at 8:03 AM
    Aw9d
    Aw9d That one guy
    Run your truck to autozone and at least find out what the code is for.
  16. Jul 23, 2012 at 9:30 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    X2 on autozone for the code. If it's nothing major pull the battery for 20 min to reset the ECU. If they pulled the battery for some reason it tends to confuse the ECU... I know mine does and the TRAC light will randomly come on a few times then after like the 3rd trip it stops doing it.
  17. Jul 23, 2012 at 1:00 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Trac control light should be a faulty communication between speed sensor and CU. However, ABS and Brake light should go off as well as those are dependent on the sensor. As for check engine light a sensor might of been knocked while they were doing the change, or could be related to the CODE for the trac control.
    He's got a 2010 and should be under warranty. He needs to take it back and explain to them exactly what happened. Dealer should take care of him from there.
  18. Jul 23, 2012 at 1:01 PM
    babytruck
    NorCal
    Dammit, Phil! It's because it's much more easily frustrating to ask here than to take it to the dealer.
  19. Jul 23, 2012 at 1:03 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Obviously lol
  20. Jul 23, 2012 at 1:10 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had the same ones lit up...ended up being the gas cap. The thing wasn't even screwed down...took quite awhile for the light to come on.
