light on my dash lit up... help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 604YOTA, Dec 18, 2013.
  1. Dec 18, 2013 at 10:36 PM
    604YOTA
    604YOTA [OP] Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    I sit at about 500rpm
  2. Dec 18, 2013 at 11:15 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    You said that you had just flushed the coolant? Perhaps it still has air pockets in the system? This can cause the sensor to show hot when the coolant temp is actually normal. Did it stop sucking coolant from the overflow reservoir and you topped it off?
    Could be something else but being as it hadn't done that before the flush, but does afterwards, it is something to consider. Good luck OP!
  3. Dec 18, 2013 at 11:37 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    I did the flush about 2 month back and everything has been fine until today
  4. Dec 18, 2013 at 11:39 PM
    Loggerhead
    Seán
    Alaska
    Probably not an air pocket then. Could be a faulty temp sensor . . .
  5. Dec 19, 2013 at 11:45 AM
    BnbBlitz
    BnbBlitz Well-Known Member
    over the rainbow
    13 DCLB 4WD
    Idle should be between 5 and 600. I'm assuming an air pocket. A pocket of hot air in the cooling system sitting on or next to the ECT sensor will cause the Coolant light to illuminate. If you didn't burp the system while filling with coolant, there still could be an air pocket hiding in there
  6. Dec 19, 2013 at 11:56 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Any idea of what the actual fluid temps are when this is happening?
    If you have access to an OBDII scanner like a scangauge or an ultragauge, they will tell you whether or not there is a problem. I have found the stock dash temp gauge to be a very poor indicator of small changes in fluid temps.
  7. Dec 19, 2013 at 12:09 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Unplugging the battery will clear an OBDII code, but it will clear a sensor-driven light such as washer fluid, low fuel, temperature, etc.
  8. Dec 19, 2013 at 9:39 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Thinking it might be my coolant temp sensor... or the wiring going to it shorted..
    Question is in order to change the part it seems to be under the intake manifold is there an easier way to get to it or take it out without removing the manifold?
  9. Dec 21, 2013 at 9:32 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    It everything else electrical is working and the engine is starting normally, check the terminal connection on the coolant temperature sensor. It might just be loose. Otherwise, before you spend a lot of money or time troubleshooting your wiring, clean and tighten your terminal connections, especially the ground connection between the frame and the engine block and battery posts. If that does not fix the problem, replace the sensor.
  10. Dec 21, 2013 at 2:40 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Is this the ground to the sensor
    This is not the ground to the coolant sensor stupid Haynes Manuel..
  11. Dec 29, 2013 at 4:44 PM
    Tanner757
    Tanner757 Well-Known Member
    Tanner
    virginia beach
    2003 tacoma v6 4door 4x4 swap
    new radio removed mudflaps weld typhoons bed lined bumper Cb radio air resenator removal flowmaster outlaw
    I have this light come on when i turn my headlights/parking lights on, its the same color as the rest of my dash lights an only comes on when i turn my lights on and goes out when i turn them off not sure why anyone else have this problem
  12. Dec 29, 2013 at 4:48 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Same problem I'm still having. Trying to find a buddy with a scanner but so far no luck.. I'm going to unplug my coolant temp sensor and see if it goes away.. have a feeling its a electrical short. Still have no clue what the fuse is that the system runs off of..
  13. Dec 29, 2013 at 5:01 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Wait a minute. You guys are saying that light comes on only when the parking lights and lights are on? Do you guys have an actual temp gauge like in this pic all the way to the left? If so that light just shows that that gauge reads the temp
  14. Dec 29, 2013 at 5:02 PM
    Tanner757
    Tanner
    virginia beach
    Well that answers my question haha thanks
  15. Dec 29, 2013 at 5:08 PM
    #35
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Glad I could help
  16. Dec 29, 2013 at 5:11 PM
    #36
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    LOL!!!!!!!!!!!!!!!!!!!
    And here I thought it was mixed in with the idiot lights on the cluster.
  17. Dec 29, 2013 at 5:15 PM
    #37
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    Burp/bleed the radiator. You may have air in the system causing the light to come on.
  18. Dec 29, 2013 at 5:17 PM
    #38
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Haha so did I until they said it only comes on with the parking lights and head lights than I knew exactly what it was.
  19. Dec 29, 2013 at 5:17 PM
    #39
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Strange because mine was out before maybe the bulb is starting to go. Its only come on in the past week maybe it was a loose connection? Hmm well its on now..lol I feel very stupid
  20. Dec 29, 2013 at 5:18 PM
    #40
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Flame away guys I'm getting a laugh out of it too
