Light out in heater/AC control panel
Discussion in '1st Gen. Tacomas (1995-2004)' started by soccersmitty55, Nov 22, 2013.
  1. Nov 1, 2018 at 10:21 AM
    Jaybreezy4x4
    Jaybreezy4x4 Member
    Justin
    N.C.
    10' Tacoma DCSB TRD Off Road
    Having the same problem with my 2010, only difference is the fan speed dial does not work at all now. Temp and air positioning dial still works but no light at all. Ac/Heat also works but I can't use it due to the fan speed dial not working. I have taken it apart and the connections were are still in great shape and even inside the dial was in great shape except a little bit of old grease from factory with I cleaned and replaced, just reinstalled and still nothing. Anybody had this problem?? 30° here and its like my heat is just taunting me in the mornings on the way to work
    Manfred likes this.
  2. Nov 1, 2018 at 5:06 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    posting here may be a better route, as they are the 2nd Gen
    https://www.tacomaworld.com/forums/2nd-gen-tacomas-2005-2015.5/
  3. Feb 5, 2021 at 7:02 AM
    tcoff5501
    tcoff5501 New Member
    Tim
    2011 Tacoma sr5 v6 2nd generation
    I just replaced mine and it's a connection issue. if I push around on bulb housing it goes on, but within a day they are out again. Do led replacement make a better connection?
  4. Nov 13, 2021 at 9:56 PM
    Chicago77
    Chicago77 Well-Known Member
    If you tap/press it and it works for a bit it is either a poor connection on a cable, or cold solder. LEDs are known to have poor solder connections that fail over time, they rarely fail on their own. You can cover with flux and tap each side with a soldering iron to reflow the solder. Some day I will pull mine out and see which is failing.
