light racin uca adjustment setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy.allen, Jul 22, 2010.
  1. Jul 22, 2010 at 6:32 PM
    jeremy.allen
    jeremy.allen [OP] Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    I have an '07 TRD OR 4X4, with a 3 inch lift with 285/70/17 MT/R's. OME 885 coils, add-a-leaf and 5100's on all four corners, front's set at 0 of course. I got my LR UCA's in and I am getting ready to install them. I know my caster after the alignment needs to be +2 degrees. Should I set the ball joints at +2 before the install and have the alignment shop zero out the factory setting or set the ball-joint adjustment at zero when I install the UCA's? I searched for about an hour on here with no luck. Any of you guys running these UCA's help is appreciated, thanks.
  2. Jul 22, 2010 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Set them at 0*
  3. Jul 22, 2010 at 7:04 PM
    splitbolt
    splitbolt Well-Known Member
    Arkansas
    2016 TRD OFFROAD DCSB MGM
  4. Jul 22, 2010 at 8:26 PM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    what they said!!!
  5. Jul 26, 2010 at 3:07 PM
    jeremy.allen
    Jeremy
    The Ville, Ky
    07 DC, OR
    Thanks, guys! I never even thought to check youtube. Preciate the help.
