Light Racing Arms & Ultimate Lift , Alignment issues ?
Discussion in 'Suspension' started by th1148, Jul 20, 2009.
  1. Jul 20, 2009 at 5:19 PM
    th1148
    th1148 [OP] Member
    Oklahoma City
    2009 DCSB TRD Sport 4x4 Black Sand Pearl
    This weekend I installed the ToyTec Ultimate kit and Light Racing Arms on my 09 Tacoma. Today I took the truck to my local Toyota dealership to have them align the truck. The tech adjusted the control arms to fix the camber but said that the caster was not in spec. The truck seemed to wonder a bit on the Interstate not sure if it was cause alignment, the terrible Oklahoma roads or the 30mph winds. Attached are pictures of the control arm settings.
    The alignment print out showed:
    Camber left 1.1/ right 0.9
    Caster left 4.5/ right 4.4
    Toe left 0.04/ right 0.04
    SAI left 11.2/ right 11.9
    Included angle left 12.3/ right 12.9
    Should I take the truck to another shop or will these settings be ok? Anyone recommend a good alignment shop around Oklahoma City? :confused:
  2. Jul 20, 2009 at 5:25 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    High positive caster is fine. Truck should drive nice and straight down the road. However you camber is too positive. even on the right side. I prefer it to be .5 or less. Toe looks good. The Positive camber will tend to cause the outer edge of your tires to wear.
  3. Jul 20, 2009 at 5:46 PM
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
    How difficult were the UCA's to install? i ordered them too just haven't installed them yet.
  4. Jul 20, 2009 at 5:54 PM
    th1148
    th1148 [OP] Member
    Oklahoma City
    The hardest part was getting the long bolt out had to bent the inner fender out a bit to get it out. The directions actually mentioned cutting the head of the bolt off and getting new ones from Toyota. Not sure how cost effective that would be or how long it would take them to get the bolts in. Overall the install wasn't that hard, just not sure what to do about the alignment issues.
  5. Jul 20, 2009 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Get the Camber adjusted closer to 0*.
  6. Jul 20, 2009 at 6:27 PM
    th1148
    th1148 [OP] Member
    Oklahoma City
    Chris, The tech said that was all he could do with the camber. By looking at how the ball joint is adjusted looks to me that I could be turned 90* maybe but would that also change the caster? Do you have any experience with these arms?
  7. Jul 20, 2009 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No personal experiance, but I belive you CAN rotate the ball joint mount. You should be closer to 0* Camber, 0* Toe, and around 2.5* to 3* Caster.
  8. Jul 20, 2009 at 6:44 PM
    th1148
    th1148 [OP] Member
    Oklahoma City
    Thanks Chris. I looked again and there is a little bit more room to move the ball joint inboard. That should help the camber shouldn't it?
  9. Jul 20, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes.
  10. Jul 20, 2009 at 7:53 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    what position did you set your ball joints to according to the paper it came with? i originally set mine to +2.5* and when it was aligned it was all out of whack. i reset the ball joint to 0* position and it aligned perfectly.
    make sure you tell the technician that the majority of his adjusting needs to come with the lower control arms. he should not have to adjust the uca much at all
  11. Jul 21, 2009 at 5:18 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    the looks of your pics. dont look like mine.u have way to much(flat spacer)sticking out on either side depending on which pic. it is.i have nothing sticking out from under the arm.
  12. Jul 21, 2009 at 6:12 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Exact setup I'm running and got mine back into factory specs. Mechanic even made a comment about how easy it was to do. Oh, the easy way to install the UCA's is to just cut the bolts and install new ones. Just be sure your dealership has them in stock.
  13. Jul 21, 2009 at 6:22 PM
    Ranger08
    Ranger08 Well-Known Member
    North Carolina
    2009 4x4 Double Cab
    Stock
    I installed the same kit and tires on a 09 DC. The Tech was able to get the adjustments with in the factory specs. The only thing that needed any real adjusting was the toe.
    I watched the Tech work on mine.
