Light Racing/SPC UCA's
Discussion in 'Suspension' started by jflan, Dec 5, 2011.
  1. Dec 5, 2011 at 12:44 PM
    jflan
    jflan [OP] Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I have these along with an OME lift package arriving soon.
    I have a couple of questions about the LR UCA's.
    1. Should I use lube under flat washers ?
    2. Should I lube the frame bolt ?
    3. If yes, what kind of lube would be rubber-friendly ?
    4. What about lube for the supplied ball joint ?
    How is that serviced ?
  2. Dec 6, 2011 at 9:50 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    when i did mine i used no lube.as for the ball joint,it was pre lubed.got almost 50,000 miles on them with no problems
  3. Dec 6, 2011 at 12:21 PM
    jflan
    Vancouver, WA
    Thanks
  4. Dec 6, 2011 at 1:03 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no probem
