light racing UCA help
Discussion in '1st Gen. Tacomas (1995-2004)' started by mixaro, Dec 28, 2013.
  1. Dec 28, 2013 at 11:57 AM
    mixaro
    mixaro [OP] Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    was just wondering if anyone else has had this problem. Last year went to get my trucked aligned and the ball joint on my LR UCA was toast along with the bushing, so specialty products sent me new ones. Now fast forward to last week. I noticed that my tires were wearing a little funny so i brought it over to my friends shop, and guess what the ball joints are shot again. Now i don't wheel my truck, sadly its more of a mall crawler (learned along time ago don't wheel a daily driver). Anyway has anyone else had this problem?
  2. Dec 28, 2013 at 11:58 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Brutalguyracing has had his LR UCA BJ's replaced a couple times
  3. Dec 28, 2013 at 12:00 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I've heard of others having this same problem. You get what you pay for, is the old saying. Go cheap, get cheap.
  4. Dec 28, 2013 at 12:00 PM
    mixaro
    maine
    nice ha ha you would think that they would last a little long.
  5. Dec 28, 2013 at 12:09 PM
    na8rboy
    WI
    You would think so...
  6. Dec 28, 2013 at 12:12 PM
    mixaro
    maine
    the thing is that they really weren't that cheap i mean they're only $150 cheaper then Camburgs. I just figured i would try them because i like the idea of adjustment with them.
  7. Dec 28, 2013 at 12:13 PM
    OZ-T
    Peter North
    British Columbia
    :rolleyes:
  8. Dec 28, 2013 at 1:12 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Mine have been just fine :notsure:. Ive heard some issues early on with the LR ball joints but those were corrected (allegedly).
  9. Dec 28, 2013 at 1:17 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The problem is the amount of lubrication that is in the BJ from when it is shipped. If you don't lube them when you get them, the amount that is in there may not with stand weather and abuse. The last set of LR UCA's that I instaleed had significantly more lube in the BJ's than any of the previous ones, and they changed their lube to a different type as well. They may have finally figured out that the lack proper lubrication has been their problem and future sets will be OK.
  10. Dec 28, 2013 at 1:29 PM
    mixaro
    maine
    well I have to wait until monday to get a hold of SPC, but i hope that they will replace them. Also if they look like the need more lube what should i put in there?
  11. Dec 28, 2013 at 1:43 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I've taken the boots off of them and cleaned all the old grease out with a rag. Then whatever grease that you use for your drive shaft is fine, but if you want, I would recommend Lucas Red N Tacky. When you do lube them, over lubing is not a bad thing, really get it in there and work the joint around, then put some in the boot and slide it back on, then re clamp it. Once it's back together, make sure you purge all the excess lube out before tightening them to the spindle. You can do this by pulling the boot as far out as you can while it is still clamped to the BJ and inserting a small screw driver or an awl between the post and the boot, then press the boot down as far as it will go to purge all the air and excess grease out of the boot. You want to really compress the boot, because when you install the BJ to the spindle, the boot will be compressed and you don't want it to over expand the rubber.
  12. Jan 2, 2014 at 9:59 PM
    mixaro
    maine
    just to post an update, SPC is sending ball joints for free, now that pretty good customer service i think
  13. Jan 3, 2014 at 8:23 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^I'm glad they are taking care of you. Were they interested in looking at your old set to see what went wrong with them?
  14. Jan 5, 2014 at 5:34 PM
    mixaro
    maine
    not really they just wanted me to email them some pictures of them, even though pictures don't really show that they had play in them. But hey i'm impressed with their customer service!
