Light racing uca help
Discussion in 'Suspension' started by mpatrick, Aug 25, 2016.
  1. Aug 25, 2016 at 6:16 PM
    mpatrick
    mpatrick [OP] Well-Known Member
    Mason
    Rancho Cucamongbruh
    2019 TRD Offroad 4x4
    Bro Dozer II
    Hey TW. So I'm running light racin upper control arms. I've been hearing a sounds in my passenger side upper control arm recently and it's getting worse. Any one have any input as to what it could be? I'm thinking maybe the ball joint? Sounds like crap and don't want to take my truck all apart yet. Thanks for any help!
  2. Aug 25, 2016 at 6:53 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Do you have the greasable ball joint LR UCA's? If so, Id give it a few pumps and make sure everything is tight.
  3. Aug 25, 2016 at 7:20 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Believe so. They are the newer ball joints.
  4. Aug 25, 2016 at 7:23 PM
    medic2230
    Murph
    Bama! Roll Tide
    Check your UCA nut on the long bolt to make sure it didn't work it's way loose. Mine did the same thing and that's what I found.
  5. Aug 25, 2016 at 7:31 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    The one connected to the spindle?
  6. Aug 25, 2016 at 9:49 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I think he's referring to the main long bolt at the top that you can reach with the tires on.
    medic2230 likes this.
  7. Aug 25, 2016 at 9:51 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    I see, I'll defiantly check that tomorrow
  8. Aug 25, 2016 at 9:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yup, this one.
  9. Aug 25, 2016 at 9:53 PM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    good luck. i'm planning to install tomorrow. wish me luck. already prepared the new UCAs. Attempted the install this evening but ran out of time before I got the first bolt off. Rather do it with a clear head, more light, and possibly a friend that's done it.
  10. Aug 25, 2016 at 9:55 PM
    medic2230
    Murph
    Bama! Roll Tide
    The one that holds the ball joint in should, yes.
    83 lbs on the long main bolt.
    Watt maker likes this.
  11. Aug 25, 2016 at 9:59 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    It's not bad, just take your time and start early to beat the heat
  12. Aug 25, 2016 at 10:10 PM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Copy that
  13. Oct 1, 2016 at 6:30 PM
    TRDrh
    TRDrh Well-Known Member
    Richard
    SoCal
    Mason,
    Any updates on this? I am getting some noise on the driver side when i hit some dips, and I also have some LR UCAs. I might have a ball joint that is ripping, because I have some grease coming out. I haven't checked it in daylight yet.
  14. Oct 2, 2016 at 10:02 AM
    mpatrick
    Mason
    Rancho Cucamongbruh
    Bro Dozer II
    Yes, in the process of replacing my passenger side ball joint. Will actually be replacing both sides and greasing them till they drown. Passenger side was bone raw.
    TRDrh[QUOTED] likes this.
  15. Oct 3, 2016 at 7:30 AM
    TRDrh
    Richard
    SoCal
    Cool. Thanks for responding. I'm going to con tr car SPC today.
  16. Oct 29, 2016 at 8:39 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Do the LR Uca`s have a greaseable fitting on them ? How are you guys keeping them lubed?
    LoMa likes this.
  17. Dec 29, 2016 at 1:06 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    No wonder I couldn't get mine loose. I asked the shop doing my alignment to grease the ball joint for me.
    Any idea what size that nut is? It's huge, I'll have to get a new socket for it.
  18. Dec 29, 2016 at 1:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The new ones do on the ball joint
    Kyitty likes this.
  19. Jan 3, 2017 at 10:45 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    So, I think I need to replace both ball joints on my SPC LR UCA's. Both have this much movement and noise coming from them:
    https://youtu.be/wAnQlPVrKGw
    Installed in May 2014 at 22,326 miles, now sitting at 40,500 miles. So just over 18,000 miles. Mine aren't the grease-able variety, but even still I expected them to last longer than 18,000 miles.....
  20. Jan 3, 2017 at 11:13 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Call SPC directly for warranty if you're in warranty period. I had a little play in my passenger side when I had an alignment done. Took about an hour and I had them shipping out replacements for a $50 core charge. About a week later I had a local shop install the new ones and then shipped my old ones back. Got my $50 core charge back too. SPC was super easy to deal with. The new ball joints are grease-able where as the original design were not.
