Light Racing UCA Install
Discussion in 'Suspension' started by avengedkevinfold, Feb 1, 2011.
  1. Feb 1, 2011 at 10:58 AM
    avengedkevinfold
    avengedkevinfold [OP] Well-Known Member
    Kevin
    Socal - OC - Huntington Beach
    bilstien 5100s all the way around, ICON progressive 3 leaf kit, Illegal tint, snuglid SL, seatbelt chime mod. light racing UCAs
    Anybody have the instructions that come with these? Maybe a PDF online somewhere?
    Also when I install these I know that I need a ball join separator to remove the factory arm.....do I need a ball joint press as well?
  2. Feb 23, 2011 at 8:33 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Yes pleas any one?
  3. Feb 23, 2011 at 9:16 PM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    Try this link.
    http://www.spcalignment.com/PROD_DIR/SPC_PROD_INSTALL.cfm?cmd=25470ins.txt&cmd2=25470
    The LR units have +2 Deg of caster built in. When you set them at 0 you are actually already at +2 caster compared to your stock arms. If you set your LR units to 0 the alignment tech can add 2 deg more or subtract 2 deg by sliding the ball joint in or out. Which would give you a range of +0 to +4 deg compared to your stock setup.
  4. Feb 23, 2011 at 9:24 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    As far as separating the ball joint goes I popped my free with a 3 pound hammer. It doesn't really matter if you screw up the threads because the new LR units come with a new ball joint. The one on the stock unit will be disgarded with the stock UCA. I did temporarily remove the sway bar link that is just below the stock ball joint just so I could get a bigger swing at it. It came apart pretty easily and mine is a 120,000 mile rig.
    When you put the new unit in you just crank down the bolt to seat the ball joint.
  5. Mar 5, 2013 at 12:12 PM
    Sandman614
    Sandman614 Travis #hotsavannahdotcom, LRGRNR
    Tim
    Boone, NC\Garner, NC
    '06 SR5 Off Road
  6. Mar 5, 2013 at 2:54 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Nope like valley viking said a mini sledge will do the trick. Just make sure you remove the bracket for the brake line. Give the spindle a nice whack up top before you start beating upwards on the UCA. One of mine came lose by just whacking the spindle. Then its nice to either have an extra pair of hand or zipties ready to go right next to you, especially if the sway bar is removed because you will need something to temporarily secure the spindle so you don't stretch the brake and data lines.
  7. Mar 6, 2013 at 12:15 AM
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
  8. Aug 7, 2013 at 11:16 PM
    Gwcolley
    Gwcolley New Member
    Garrett
    Santa Clarita, CA
    2011 4x4
    Installing some LR uc arms this weekend...I have the directions. Any words of advice before I start to make it easier on me.
  9. Aug 7, 2013 at 11:17 PM
    Gwcolley
    Gwcolley New Member
    Garrett
    Santa Clarita, CA
    2011 4x4
    I also noticed there are no grease zerks. Do you need to remove and freeze from time to time.
  10. Aug 7, 2013 at 11:19 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    If you need help I can install them. Ive done prolly around 10 sets of 2nd gen Tacoma UCA installs.
    Also, you will not need a ball joint press. I have installed these before and the ball joint slips right into the light racing arm. As for removing the stock UCA from the spindle, we use a penetrating oil and a rubber dead blow. This way, it saves the stock ball joints rubber covers.
  11. Aug 7, 2013 at 11:26 PM
    Hiatt1991
    Hiatt
    Make sure you have all the proper tools laid out in front of you. Best way is to droop out the suspension, remove the castle nut and cotter pin that connects the UCA to the spindle, soak the fitting where the ball joint slips into the spindle with penetrating oil, let it sit for 5-10 min, then pound the arm of the UCA with a dead blow hammer till the ball joint end pops out of the spindle, then remove the UCA pivot bolt by bending the sheet metal and pounding it out partly with a punch and pulling it out. Penetrating oil makes it a lot easier. Then install the arm and torque everything.
  12. Aug 8, 2013 at 3:04 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    ^this.
  13. Aug 8, 2013 at 3:32 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Read through this thread. Obviously they're not LR UCAs but most of the steps are the same. Gives you some pictures for reference. It was a lot harder for me to get the long UCA bolts out then people make it sound like but overall the job isn't too hard.
    http://www.tacomaworld.com/forum/suspension/14507-total-chaos-uca-how-install.html
  14. Aug 8, 2013 at 3:43 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    When you separate the ball joint from the spindle either have a extra set of hands in there, or have zip ties or a bungee right next to you, you need to secure the spindle, and if you let go of it you might put to much tensions on your brake/data lines.
  15. Aug 8, 2013 at 3:47 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    sub, doing this soon
  16. Aug 8, 2013 at 4:01 AM
    Gwcolley
    Gwcolley New Member
    Garrett
    Santa Clarita, CA
    2011 4x4
    Thanks for the tips, doesn't sound to Hard. I just don't want to mess up my pride and joy. ..just want to say this is an awesome forum lots of knowledge here.
  17. Aug 8, 2013 at 4:09 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Its not to hard. You might find it easier to re install the long UCA bolt the opposite way, its easier to get out next time if you install it the opposite way.
  18. Nov 29, 2013 at 5:00 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    ^^^^^x2..oil is your friend..^^^^
  19. Dec 4, 2013 at 2:52 PM
    octoyotaco
    octoyotaco Well-Known Member
    C
    Orange County
    If anyone is selling a pair of these UCA's please let me know
  20. Dec 16, 2013 at 8:26 AM
    ST3VE
    ST3VE Well-Known Member
    Bel Air, MD
    Tundra Crew Max
    Tint, car seat, baby wipes
    Can I bump this please?
    I installed these UCA's and I have a bit of camber still. Has anyone else ran into this problem? I had it aligned but still kicked out a little. I am taking it to a different shop after work today (with a PDF printout) ... just curious if this is a common problem?
