Light racing UCA question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspetrovitsis, Feb 8, 2012.
  1. Feb 8, 2012 at 6:29 PM
    jspetrovitsis
    jspetrovitsis [OP] Well-Known Member
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    Toytec/Eibach front coils, Bilsteins on all four, 2 '' AAL, Light Racing UCA, K&N CAI, Weathertecs front and back, Wet Okoles, Alpine INA W900BT in dash navigation, LED cab lights
    I had LR UCAs installed a few weeks ago and I am hearing noises from the front end that sound like it is shifting around. I also noticed that the guy that installed them left 4 washers in the box that were not used. Does anyone know if these are soposed to be used??? I have a 2011 txPro if that makes a difference.
  2. Feb 8, 2012 at 6:31 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    There are spacer washers that go on the inner side of the UCA / bolt connection
    I'll find a pic
  3. Feb 8, 2012 at 6:33 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    when he installed it, I am pretty sure he just used the hardware that was on the stock UCAs
  4. Feb 8, 2012 at 6:34 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    derp
  5. Feb 8, 2012 at 6:35 PM
    OZ-T
    Peter North
    British Columbia
  6. Feb 8, 2012 at 6:48 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    hmm alright, has anyone installed these and had left over washers when finished???
  7. Feb 8, 2012 at 6:49 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Actually, come to think of it, I did have a leftover one because I forgot to replace one of the stock washers.
  8. Feb 8, 2012 at 6:56 PM
    OZ-T
    Peter North
    British Columbia
    I didn't have anything left over
  9. Feb 8, 2012 at 6:57 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    x2...on a semi-related note, did they just change the torque specs to 150 ft lbs?
  10. Feb 8, 2012 at 6:57 PM
    OZ-T
    Peter North
    British Columbia
    Are the left over washers the big ones in the diagram or the smaller spacers ?
  11. Feb 8, 2012 at 7:30 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Should use washers they provide plus the 2 on each side stock.
  12. Feb 8, 2012 at 7:37 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Here are 2 pics of mine installed. Step ten tells you to load the suspension before tightening the upper bolt completely.
    I found I had a popping type noise coming from one side. It was that I didn't have it tight enough. Mainly could be heard going into or out of reverse or slow off camber turns.
  13. Feb 8, 2012 at 8:49 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    yeah that is exactly when the noise happens, doesn't happen all the time but when i can tell there is pressure being put on the UCA i hear it. what did you do to fix this and did you have to realign it after???
  14. Feb 8, 2012 at 10:02 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    They are the 4 smaller ones. is it possible that the stock ones could have been reused?
  15. Feb 8, 2012 at 10:13 PM
    OZ-T
    Peter North
    British Columbia
    Do the stock UCA's even have those spacers ?
    There is a total of 8 smaller spacers between the two UCA's , are the inner ones or the outers missing ? You should be able to see the outers if they are there .
  16. Feb 8, 2012 at 11:19 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    No the stock ones only have the two outer washers. You need to use those and the provided washers. Should be NO washers left over.
  17. Feb 9, 2012 at 6:00 AM
    TacoAlaMode
    Brian
    Huntsville AL
    Like OZ said, I don't think stock has them. First thing you need to do is check the diagram OZ linked and check for the washers. You can see one in both of the pics I attached.
    Since I skipped step ten, I got my wheels up, loosened the long bolt a little, set it back down and retorqued. It is hard reaching past the tire, but that took care of it for me.
  18. Feb 9, 2012 at 4:30 PM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    Sorry to get off topic but does anyone have a how to on LR UCA's? I ordered some from wheelers recently. Cant wait to install.
  19. Feb 9, 2012 at 4:31 PM
    OZ-T
    Peter North
    British Columbia
    How to what ?
  20. Feb 9, 2012 at 4:34 PM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    Install LR UCA's. Sorry about that!
