Light Racing UCA questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gincoma, Jul 14, 2014.
  1. Sep 17, 2014 at 5:56 AM
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    If thats all you messed with it and it looks and drives good then its up to you. Shouldn't effect toe. I would get an alignment. Probably better safe then sorry as far as your tire wear goes. I'll probably get one in the next month or so.
  2. Sep 17, 2014 at 8:08 AM
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Yeah they usually dont touch the upper control arm. I told them not to when i did mine. They can get a little adj from the LCA. If you loosen that bolt while on the ground it will slide all the way in immediately (spindle will go right into spring probably).
  3. Sep 17, 2014 at 8:55 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You loosen the top nut , slide the top of the tire towards or away from the truck , re-torque the top nut , camber adjustment complete
    Have you read the install instructions ?
  4. Sep 17, 2014 at 8:57 AM
    OZ-T
    Peter North
    British Columbia
    Use a torque wrench
  5. Sep 17, 2014 at 9:03 AM
    OZ-T
    Peter North
    British Columbia
    That adjustment only effects camber
    You generally should start with your LCA cams at a neutral position , set the LR UCA ball joint at your desired caster setting , align the truck as close as you can with the LCA cams , get the caster and toe where you want it and if you need to tweak the camber you can do that at the top nut of the LR UCA
    bjMoose has a great thread on LR UCA adjustments , I'll see if I can find it , hang on
  6. Sep 17, 2014 at 9:04 AM
    OZ-T
    Peter North
    British Columbia
  7. Sep 17, 2014 at 9:25 AM
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    Dude!! They were way past 150ftlbs. You can't hide behind the fact in my situation they failed. And have with may others the end. Off this thread now. If you wheel hard. GL with LR
  8. Sep 17, 2014 at 9:38 AM
    OZ-T
    Peter North
    British Columbia
    There is no such thing as over torquing ?
  9. Sep 17, 2014 at 9:39 AM
    OZ-T
    Peter North
    British Columbia
    We did mine on the rack , yes
  10. Sep 17, 2014 at 9:53 AM
    OZ-T
    Peter North
    British Columbia
    No , it was on the alignment rack
  11. Sep 17, 2014 at 12:11 PM
    OZ-T
    Peter North
    British Columbia
    This is exactly whatI did too
