Light Racing, UCA - Whats are "Good" Alignment #'s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Sep 21, 2022.
  1. Sep 21, 2022 at 4:53 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I had to replace the upper and lower ball joints so need an alignment.
    I assume the stock alignment numbers aren't the way to go with King Stage 3's ?
    What are some good alignment numbers you can share with me?
    THANKS!
  2. Sep 21, 2022 at 7:30 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Still want to be near stock #'s. Question is can stock #'s be attained. Since you have SPC UCAs, you should be able to do that. So, toe would be close to zero, with slight positive toe, camber would be close to zero with slight positive camber and depending on the tire, wheels, and lift, you might want at least 2.5* or more of caster. Too much caster, say over 4.5 to 5* might make your wheel feel heavy, especially in turns. Also a bit more caster (.3 to.5* more positive) on the passenger side helps with road crown.
