Light Racing uca
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iitywygms, Jul 28, 2016.
  1. Aug 12, 2016 at 6:50 PM
    docseano
    docseano Well-Known Member
    2015 Tacoma 4x4
    Brute Force Fab custom front and rear bumpers, Bilstein 5100's with OME 886's, AllPro Offroad sliders, soft top, mesh raptor grill kit, Flowmaster 40 series muffler, diamond plated door sill protectors
    Nice thread guys. I have 2 questions…..when installing the UCA's, how did you remove that long bolt on the passenger side?? And in regards to caster/alignment, I will be having ~2.5in of lift, which would be the best setting? the instructions say to set at "D" which is 2.0
  2. Aug 13, 2016 at 1:04 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    X2 Bump
  3. Dec 30, 2016 at 9:55 AM
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    i cut the bolt and threaded the new one in backwards
  4. Dec 30, 2016 at 10:02 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Did you go up in tire size the same time you installed the UCA's?
  5. Dec 30, 2016 at 10:04 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Cutting the bolt would be the easiest route but it can also be removed through a little bending of the inner fender. It's not that difficult, just takes a bit more time. I haven't purchased the bolts but I though I saw a thread stating they run about $30 a pair.
  6. Dec 30, 2016 at 10:09 AM
    eon_blue
    Azusa, CA
    @uhplifted didn't you have to cut your bolt to get your's off? I seem to remember Steve doing that since you had new bolts to go with the new UCAs if I recall correctly.
  7. Dec 30, 2016 at 10:10 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Bend the inner fender , be aware that there are some hard fluid lines in that area
  8. Dec 30, 2016 at 10:25 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The bolts don't have to cut but some people have trouble taking them out. LR UCA's don't come with that long bolt. I don't think any other brands do as well.
  9. Dec 30, 2016 at 10:27 AM
    eon_blue
    Azusa, CA
    If I remember right I think he had bought new ones knowing that they were likely going to have to cut the old ones to get them out, if only because it was a lot easier. When I got my LR UCAs installed we didn't have to cut the bolt, but it was easier to get to on my first gen.
  10. Dec 30, 2016 at 10:28 AM
    eon_blue
    Azusa, CA
    Since we're on the subject of SPC Light Racing UCAs, does anyone else have grease coming out of their boots? Mine come out pretty bad on one side, the boot doesn't seal on the bottom and the grease oozes out especially after off-roading. I usually just put another pump or two in after each outing, haven't had any issues with them in the 5k miles I've put on them so far. But it's a little concerning, I wasn't sure if that was supposed to happen or not since I know SPC recommends adding a pump of grease every so often, the old grease has to come out somewhere I guess?
    In another thread though, someone linked a page from SPC's website saying that the boots are "sealed" and mine definitely aren't.
  11. Dec 30, 2016 at 10:29 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It's not that much harder on 2nd gens as I've done about 3 installs. Driver side was harder to get to because of the battery and some hard lines like Oz-T stated above. The bolt can be wiggled out but the inner fender has to be bent.
  12. Dec 30, 2016 at 10:32 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Ya I cut both bolts cuz it took too long. One we couldn't even get out
    eon_blue[QUOTED] likes this.
  13. Dec 30, 2016 at 10:35 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I think the real question is why Toyota put the bolt in that way in the first place and should we be putting the bolt back the same way.
  14. Dec 30, 2016 at 10:44 AM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    I just installed the JBA uca's on wednesday and didnt have too much trouble doing the install.I have a 2.75 inches of lift up front and set my caster to 3.5 and it drives great.
  15. Dec 30, 2016 at 12:35 PM
    #35
    OZ-T
    Peter North
    British Columbia
    Theorectically , installed backwards , if the nut ever came off the bolt could work its way out by gravity
  16. Dec 30, 2016 at 1:14 PM
    #36
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I thought about that as well but if I remember correctly on the lower control arms, the strut nut is on the front so if it ever gets loose, the bolt can slip off.
  17. Dec 30, 2016 at 1:25 PM
    #37
    OZ-T
    Peter North
    British Columbia
    I thought we were talking about LR UCAs
  18. Dec 30, 2016 at 1:30 PM
    #38
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Yes, we are. Sorry to be confusing. I was just comparing the UCA bolt placement to the LCA bolt.
  19. Dec 30, 2016 at 1:38 PM
    #39
    OZ-T
    Peter North
    British Columbia
    The UCA bolt is installed at an incline with the head of the bolt uphill , thats what I meant , installed backwards , the nut coming off could allow it to work itself out via gravity
  20. Dec 30, 2016 at 3:53 PM
    #40
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    Yes. 275-70r17
