Light Racing uca
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iitywygms, Jul 28, 2016.
  1. Dec 30, 2016 at 4:04 PM
    #41
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That might be what you're feeling then. Bigger, wider tires have a tendency to follow the road more. Tires are heavier so acceleration and braking is affected as well. 2.7 Caster setting is 2.7 regardless of which UCA's you're using.
  2. Jan 2, 2017 at 9:05 PM
    #42
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    I agree that the caster is 2.7. I just wonder how the change in the geometry affects handling when caster is set at A instead of D (with the light racing uppers.)
    Moving the upper to A from D (or vice versa) will move the position of the upper ball joint, so the lower has to be adjusted to match. So the center of the tire is moved relative to the adjustment of the upper control arm.
    I can get 2.7 caster with the upper set at A or D. But the tire position is changed relative to everything else. Just wondering if setting caster at 2.7 at A will be any better that setting caster with the upper set at D.
    Most likely it will feel pretty much the same?
  3. Jan 2, 2017 at 9:53 PM
    #43
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Read bjmoose's LR UCA OP
  4. Jan 2, 2017 at 9:55 PM
    #44
    OZ-T
    Peter North
    British Columbia
  5. Jan 3, 2017 at 7:22 AM
    #45
    iitywygms
    Norcal
    4x4
    I have read that thread, many times. It explains how and why you should set the uppers to achieve a desired alignment spec.
    What I could not find, is what affect setting the uppers as I described would have on handling.
    Difference in handling with Upper set at D as opposed to set at A. Both with 2.7 caster.
  6. Jan 3, 2017 at 10:14 AM
    #46
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I really don't think there will be a difference in setting to either A or D if you are getting 2.7 caster on each one. If you can get 2.7 on D setting then you would not need to set to A. It just slightly changes the angles on the UCA so you can adjust for the desired caster. 2.7 on A will be the same on D.
  7. Jan 3, 2017 at 11:19 AM
    #47
    OZ-T
    Peter North
    British Columbia
    The location of the wheel in the wheel well will be different , no ?
  8. Jan 3, 2017 at 11:53 AM
    #48
    iitywygms
    Norcal
    4x4
    Yes, that is why I am asking how it affects the handling. The caster will be at 2.7 regardless of the upper control arm setting. But the position of the wheel will be different between using A or D.
  9. Jan 3, 2017 at 12:02 PM
    #49
    OZ-T
    Peter North
    British Columbia
    I don't think it will effect the handling because the caster would be the same but it would make a difference for clearance of larger tires
  10. Jan 10, 2017 at 6:30 PM
    #50
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    are the UCAs only supposed to have washers on the outside (2 washers per bolt) or the outside and inside (4 washers per bolt)?
