Light racing uca's any good?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tatts521, Nov 14, 2015.
  1. Nov 29, 2015 at 6:56 PM
    #41
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    150 ftlbs, that's tight! Good idea on the witness marks too. When you say LCA you're referring to the cam bolts, right?
  2. Nov 29, 2015 at 7:59 PM
    #42
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah LCA cam bolts. Mark the centerline of the bolt to the frame, dont use the eccentric cam markings as a reference as they wont be as accurate. You need to know where the center of the LCA bolt was positioned in relation to the frame.
    Also, if i had to do it over again, i would have my alignment guy get the numbers that i wanted with the upper ball joint slid ALL the way outward (they are like 1/4 of an inch in right now). that away if they did somehow move, they can only move in one direction, and it would be REAL easy to know where they need to go back to.
  3. Nov 29, 2015 at 8:17 PM
    #43
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That would be giving up the extra adjustability you said you wanted...
  4. Nov 29, 2015 at 9:20 PM
    #44
    nd4spdbh
    SoCal
    only if you maxed out the LCA trying to get camber with your needed caster.... if thats the case then just spin the ball joint to get more caster to return the LCA to a more neutral setting.
    As my setup stands i still have the ability to add 2 more deg of caster (currently at 3.4* caster, -.4* camber and .1 toe in each side) on a 2in lift and the LCA adjustments are just about centered in their range front n rear bolts, leaving plenty of room for me to slide the ball joint all the way to its outer most position and still be able to get my -.4* camber
  5. Nov 29, 2015 at 11:19 PM
    #45
    medic2230
    Murph
    Bama! Roll Tide
    Been running my LR UCA's for 4 years without any trouble out of them.
  6. Nov 30, 2015 at 3:29 AM
    #46
    weldo
    Pittsburgh, pa
  7. Nov 30, 2015 at 7:58 PM
    #47
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  8. Nov 30, 2015 at 8:14 PM
    #48
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Heres the link to where I describe doing my own alignment using jberry's instructions.
    I ended up with the factory eccentrics "max caster/min camber" and then took all the caster and camber adjustment in the LR UCAs.
    That meant that the driver side was set to "Position G" (0 increased caster) while the passenger side was set to "Position D" (2 degrees increased caster)
    the bjmoose daily driver build - self alignment
  9. Aug 29, 2017 at 9:18 AM
    #49
    Twitch896
    Twitch896 Member
    06 dclb
    Ome lift all around with dakar leafs 17” kmc Rigid fogs
    Trying to get more info On this. Have an 06 dclb with fox 2.0 all around. It's my dd and minor off roading. Sounds like jba is a good choice over the lr. I guess my main concern would be proper alignment opposed to having at much travel as possible seeing as I don't off road that much. I'm New England
  10. Aug 29, 2017 at 3:15 PM
    #50
    Tatts521
    Tatts521 [OP] Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    So I've had my LR ucas for roughly 2years now. I do enjoy these will be upgrading to some dirt Kings soon.
    20RustyTaco06 likes this.
  11. Aug 29, 2017 at 3:23 PM
    #51
    Twitch896
    Twitch896 Member
    06 dclb
    I was looking into dirt kings also. Would you be staying with a ball joint or going to the uni? Doesn't seem like a lot of people are talking about their balljoint uca
  12. Aug 29, 2017 at 3:53 PM
    #52
    Tatts521
    I'm gonna go for uni ball. Lots have changed since I was looking into ucas. I do lots of off roading mostly big ass rocks out here
