Quick Links:Did I get a busted or even the correct VSV? Why you may want to change your fuel filter - '03 3.4 (More Pics added)
Oil Plug Seal
Replacement Fuel Tank - 2002 2.7L 4cyl
Bolt Size to Use with Puller, to Remove Crankshaft Timing Sprocket on 3.4L V6 5VZ-FE?
'04 Tacoma 4x4 Double Cab LBJ + Tie Rod Part Numbers
Light racing UCA's or keep what I have?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Honey badger, May 17, 2013.
