Light Switch Wire Tap (multiple switches)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Midknight, Apr 20, 2018.
  1. Apr 20, 2018 at 11:17 AM
    Midknight
    Midknight [OP] Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Hey guys,
    I'm looking to wire in a few lights to OEM style switches, similar to below.
    I'd also like to get them setup so that the switches are illuminated when I turn my lights on. My plan is to tap into the bed light switch power wire (suggested in Post #8 in the following thread):
    https://www.tacomaworld.com/threads/which-wire-can-i-tap-in-to.524302/
    My question is, is it an issue to tap the three switches into the single bed light wire?
    Cheers
  2. Apr 20, 2018 at 12:32 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I put two switches together and used posi-taps on the brown and green wires of the cargo switch;
    They illuminate with the dash lights and dim with them as well.
    Midknight[OP] likes this.
  3. Apr 20, 2018 at 12:47 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
  4. Apr 20, 2018 at 2:15 PM
    Midknight
    Western Canada
    2018 TRD Off-Road
    Right on, thanks for the note and visual :)
  5. Apr 20, 2018 at 2:15 PM
    Midknight
    Western Canada
    2018 TRD Off-Road
  6. Apr 20, 2018 at 2:34 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Using an add-a-fuse as a source for the illumination circuit won't dim the switch with the dash lights. The switch illumination would be on full all of the time. You would need a ground for the other side of the circuit as well.
