light theft prevention
Discussion in 'Lighting' started by 98Tacoma, Jan 6, 2010.
  1. Jan 6, 2010 at 10:29 PM
    98Tacoma
    98Tacoma [OP] Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    i may be posting this in the wrong place. but has anyone ever figured out how to prevent sticky handed theifs from still there nice driving fog, or off-road lights. what are the best ideas or products out there. i have brand new kc lights and spent to much to loose them. thanks
  2. Jan 6, 2010 at 11:08 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    I'm not sure there is a lot you can do about it. I know they use special screws for automobile plates that use a proprietary type of bit to back it out to prevent theft of plate.
    Maybe you can use one of those type of screws, if you are able to use that size of screw or bolt.
    Hope that helps or gives you an idea of what to do.
    [​IMG][​IMG][​IMG]
  3. Jan 6, 2010 at 11:26 PM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
  4. Jan 7, 2010 at 1:15 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I'm Running Piaa Light Locks, A few People on here has those IPF ones above.
  5. Jan 7, 2010 at 6:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Interesting....
    Those PIAA light locks - where do they go? (sorry, if that was a stupid question)
  6. Jan 7, 2010 at 6:54 AM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    No not a stupid question. They go on the bolt that holds the lights. Hope this helps
  7. Jan 7, 2010 at 7:13 AM
    Janster
    Jandy
    Lancaster, PA
    Yup! Thanks!
    I thought that was the case.
    In my case, they're installed on Aries bullbar. The nuts are up inside the tube and it's a PITA to get up in there to begin with.
  8. Jan 8, 2010 at 2:41 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
  9. Jan 8, 2010 at 3:07 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Only True way to prevent theft is to weld 2 bolts together. If they were determined, then they will do anything to steal it.
  10. Jan 8, 2010 at 9:19 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I had a a friend with a welder put a bead on the end of the bolts so you can't take the nuts off, but can still loosen them to adjust the lights. Costs less than the $40 lock nuts, but you have to cut the bolts to remove the lights.
  11. Jan 9, 2010 at 9:11 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    do you kno if only two lock nuts come in a set?
