Light Truck tires on 2025 TRD Sport?
Discussion in 'Wheels & Tires' started by Max Headroom, Feb 21, 2025.
  1. Feb 21, 2025 at 9:07 AM
    Max Headroom
    Max Headroom [OP] Member
    Max
    2025 Tacoma Sport
    So I bought this truck two weeks ago and had the dealer mount up something that would handle Colorado high-country snow better than the showroom tires. They put on some Kenda LT275/70R18s. Although they look great the ride is really bouncy and they don't do well at all on ice. Snow yes, ice ... no. And of course the speedo/odo are now off by about 5%.
    The show room tires are 265/65R18 and had a nicer ride on the test-drive. Do you think the fact that the Kendas are Light-Truck tires is to blame?
    What's a better solution? I'm afraid the jarring ride will create early squeaks and rattles on this brand-new truck.
    Max
  2. Feb 21, 2025 at 9:12 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    What load rating did they put on? Is it a C load? or E load?
  3. Feb 21, 2025 at 9:18 AM
    Max Headroom
    Max
    2025 Tacoma Sport
    I presume that's on the sidewall somwhere ... Let me look.
    Max
  4. Feb 21, 2025 at 9:28 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    You could try General Graber 285/70/R18 in load size C if the weight of the E rated isn't giving you a compliant ride. I think those weigh in a 46 or 48 pounds. Sure it might not be the best tire, but it's one of the lightest in that size, and I heard people running those on the Tundra, and are the OEM tire on F-150 Tremor. The 2025 configurator says the Tremor gets that size BFGs, which is wrong or Ford switched tire manufacturers. If those exist you could try the BFG.
  5. Feb 21, 2025 at 9:30 AM
    YF_Ryan
    Kent, WA
    I'm only seeing those in E load on a quick google search. If you aren't offroading and needing a super robust tire, or hauling super heavy (like me), E loads are unnecessary and give a really stiff ride. Check your tire pressure, too. They can be aired up to like 85 pounds for max load, but prolly need 30 for street/unloaded use.
  6. Feb 21, 2025 at 9:45 AM
    Max Headroom
    Max
    2025 Tacoma Sport
    These are load range E.
    Max
  7. Feb 21, 2025 at 11:11 AM
    YF_Ryan
    Kent, WA
    Yeah, sounds like you lost a lot of your ride quality going to those tires, which is pretty normal for those. A lot of folks on here dislike E load for that reason, that and usually having worse mileage since they can weight a lot more. There are pros and cons to those tires... but your needs don't seem to align with the pros, and you just have to deal with the cons.
  8. Feb 21, 2025 at 3:40 PM
    Max Headroom
    Max
    2025 Tacoma Sport
    Would these things be more appropriate on a Tundra? I trying to think of reasons a Toyota dealer would have them in stock.
    Max
  9. Feb 21, 2025 at 8:16 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Did you mention to the dealer you wanted to tow or hit some rocky trails?
    If your sticking to pavement or forest service roads C load or SL tires are good for your needs.
    This site is good for comparing tires and prices, weights.
  10. Feb 21, 2025 at 8:21 PM
    Max Headroom
    Max
    2025 Tacoma Sport
    No way. I just said I needed tires that were good in the snow. :-\
  11. Feb 21, 2025 at 8:28 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    They should have told you about Falken AT3w, new KO3, or Mickey Thompson Baja Boss AT, the Toyo AT3 as well. In your original tire size you have more choice in lighter tires, SL and C instead of mainly E load.
  12. Feb 21, 2025 at 8:35 PM
    Max Headroom
    Max
    2025 Tacoma Sport
    Well, these things are coming off as soon as I think the snow's done. Then I'll try to sellem.
  13. Feb 21, 2025 at 8:37 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    The KO3 in 265 70 18 is E load but only 55lbs.
    the good thing is you can run a bunch of different tire sizes on the new Gen, just depends what’s important to you.
  14. Feb 21, 2025 at 8:55 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    Load range E tires belong on an F250, IMO way too much tire for a Tacoma. I had Goodyear Wrangler DuraTrac load range C on a third gen Taco and they rode good and were good in the snow. No need for max pressure on the LR C unless you are hauling a load or trailering.
  15. Feb 21, 2025 at 9:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Get some real snow tires (Blizzak LTs) and swap them in every winter. It’s a huge world of difference in how well they perform compared to an all terrain tire.
    Sarah Claire likes this.
  16. Feb 21, 2025 at 9:42 PM
    999
    999 Well-Known Member
    Texas
    What’s the tire pressure?
