light whip for rear of truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by odinsbro15, Dec 27, 2021.
  1. Dec 27, 2021 at 10:45 AM
    odinsbro15
    odinsbro15 [OP] Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    Hey Yall, got a light whip for christmas (for wheeling) and i was wondering if anyone has wired them up to anything closer than the main battery. its requires 12V 3amps (i will add an inline fuse for it). let me know your thoughts. thanks
  2. Dec 27, 2021 at 10:55 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    How do you want to run it?
    As a thought......
    There is a 7 pin connector at the rear of the truck. You could get a mating 7 pin plug, then make the connections in the plug for the running lights to feed the whip. Many pin out diagrams for the 7 pin plug. There are also 7-4 pin conversion plugs. Splice the whip into the plug on the running light circuit. No need to tap into the brake light circuit or the turn signal circuits
    odinsbro15[OP] likes this.
