Light wiring for truck cap (camper top)
Discussion in 'Lighting' started by Corn, May 30, 2012.
  1. May 30, 2012 at 8:34 AM
    Corn
    Corn [OP] Well-Known Member
    NC
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights, suspension, wheels
    My 2000 Tacoma has a blue wire and a white wire (neutral) exposed near the rear tail light, and routed to inside the bed liner for easy access. My camper top, or bed cap, has a dome light with a black wire and a black/red striped wire. The tail light has a red wire and a black wire.
    Could someone help me in figuring out how to connect the bed cap upper tail light to function with truck brake lights.
    I'm pretty sure the blue and white wires were used previously to hook up bed cap light.
    Thanks
  2. May 30, 2012 at 8:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Tap into the truck's brake light wires. I'd use a quick disconnect type connector in there somewhere so the shell can be removed if you ever want to.
