Lightbulb fell inside headlight's housing
Discussion in 'Lighting' started by Ihatetacomas, Sep 1, 2019.
  1. Sep 1, 2019 at 10:09 AM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    So I replaced my DTRL light and, I'm assuming it wasn't in tight enough when I put it in but it fell inside the housing, just curious as to what my next plan of action should be. If I separate the housing from the screw holes along the backside of the headlight, what are the chances that the seal is ruined?
  2. Sep 1, 2019 at 10:16 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Done this a few times. Take the light off the truck and hold it upside down and shake it. Should fall out
    Xx_Evilvirus_xX likes this.
  3. Sep 1, 2019 at 12:01 PM
    Ihatetacomas
    Dylan
    Elko NV
    10/4, I'll give it a shot
  4. Sep 4, 2019 at 7:48 AM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    OP, you can either remove the headlight as suggested and shake it until it falls out or get it close to the opening or use a flexible claw grabber pickup tool long reach curve spring grip.
  5. Sep 5, 2019 at 10:08 AM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Lol ive used this claw grabber to do the same thing when i dropped mine in there :(
    Worked relatively easy tho. Whew
  6. Aug 23, 2023 at 8:53 AM
    AJ1G
    AJ1G Active Member
    Stonington, CT
    2012 2.7L Auto 4X4 SR5 Access Cab
    Similar thing just happened in the right headlight lens of my 2012 Tacoma, noticed it while detailing the truck after taking it home from the dealer after it's frame replacement last week (well actually ihe job took the last five weeks). Saw the little amber side marker bulb adrift in the bottom of the headlight lens housing, apparently it came loose during or after the truck reassembly process. Weird thing is that the following day it was gone, have no idea how it could have escaped once it was down in the bottom of the lens. Dealer service rep doesn't know either!
  7. Sep 7, 2023 at 10:09 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Frame replacement??
    That must have been hugely expensive or was it part of the frame?
  8. Sep 8, 2023 at 10:14 PM
    OPTIMUS_TACO
    OPTIMUS_TACO Member
    2023 Toyota Tacoma SR5 XP
    Carwash vacuum take off nozzle and use round diameter hose. Hope you get it out.
  9. Sep 12, 2023 at 11:54 AM
    AJ1G
    AJ1G Active Member
    Stonington, CT
    Frame was replaced on Toyota’s nickel through the frame rust frame
    replacement recall program. The original frame wasnt in very bad condition but a rust through condition was found on the right side frame
    rail that was considered severe enough to qualify for the new frame. Only cost me was about 130 dollars for some odd bits of hardware that was not included in the frame replacement parts package and my request to have them install a new serpentine belt upon putting everything back together. The old belt at 108K was actually in pretty good shape but since it had to be taken off when pulling the engine and transmission it made sense to just replace it with a new one.
    During the frame
    replacement they had to pull the
    front grille and headlight assemblies separately from the rest of the cab.
    Service manager said it would have cost me 12K dollars if not covered by the recall.
    By the way, the wayward side marker bulb has yet to re-appear inside the headlight
    lens, looks like it made a clean getaway!
  10. Sep 12, 2023 at 12:03 PM
    AJ1G
    AJ1G Active Member
    Stonington, CT
    Yes the entire frame was replaced, the replacement package also included new front end lower control arms, bushings and ball joints, and virtually all of the metal brake lines including those in the engine bay associated with the ABS control
    valve, and a whole lot of new frame attachment brackets and fasteners. Complete replacement of engine coolant, and recharge of the A/C system. The truck was completely disassembled and reassembled onto the new frame. There a lot of good stop motion videos of the Tacoma frame replacement process on YouTube.
