Lighter and Power Outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frogdaddy, Nov 15, 2009.
  1. Nov 15, 2009 at 7:24 PM
    Frogdaddy
    Frogdaddy [OP] Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    Are the lighter socket and power outlet the same? Can I lose the lighter and put the same cap or cover on the light socket? Is there a part number? I'm not a smoker and thinking cosmetically. Two caps would look better to me than one lighter and one capped power socket as is.
    Thanks
  2. Nov 15, 2009 at 7:26 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    interesting, I'd like to know also.
  3. Nov 15, 2009 at 7:28 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    This has been done, the thread is hard to find though.
  4. Nov 15, 2009 at 7:32 PM
    Frogdaddy
    Ga.
    Sorry searched lighter or outlet plug
  5. Nov 15, 2009 at 7:43 PM
    Frogdaddy
    Ga.
  6. Nov 15, 2009 at 7:44 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Not sure for tacomas. Some other vehicles ,the lighter has heavier duty components for the heat than the power port, might be amps too.
