Lightest 285/75/16 AT’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by boston23, Jan 20, 2022.
  1. Sep 4, 2022 at 3:46 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    Do the rear tires spin more easily if you full throttle launch in 1st gear? In theory loosing contact patch size is the only downside of going pizza cutter, but you're probably never going to hybroplane so that's good
  2. Sep 4, 2022 at 4:11 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    Contact patch doesn't depend on tire width (except for extreme cases, not this one). It is a function of pressure and tire construction.
    The weight of vehicle / contact patch = pressure
    The pressure you control by inflating the tire and the weight of vehicle is how much crap you have in it. Contact patch remains constant
  3. Sep 4, 2022 at 4:20 PM
    malatx
    makes sense, that's why people air down to get more contact patch.
    I guess I'll rephrase my original question to if going pizza cutter dramatically affect the grip, acceleration, braking performance
    FloridaFree[QUOTED] likes this.
  4. Sep 4, 2022 at 6:53 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    The FJ Steel Wheels are HEAVY compared to an alloy wheel. I ran them for a winter on a set of P-rated snow tires and the difference in weight between those and the TRD Sport alloy wheels was absolutely significant. I enjoyed the look but they were a pain to deal with during the switchover in the winter between the lugs, center caps and weight. If switching isn't an issue for you, that's a non-issue in terms of lugs / caps.
  5. Sep 4, 2022 at 9:03 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I havn't been able to find weights for the new Nokian Outpost AT but the tire it replaced was 47lbs in a LT285 70 17. I would guess that the new tires will be comparable
  6. Sep 12, 2022 at 2:53 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    fyi weight for the nokian outpost at (kaltire lists weights online)
    LT285/70R17 121S 49.40 lbs
    285/70R17 116T 41.7 lbs
  7. Sep 12, 2022 at 5:17 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    C load 265/75/16 Duratracs would be your lightest 285/75/16 tire. :thumbsup:
