Lightest aftermarket bumper with 885's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Aug 16, 2016.
  1. Aug 16, 2016 at 2:22 PM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Guys and gals...I knew I should have put on 886's when I did my suspension, but I didn't.
    With that being said...what is the absolute lightest aftermarket bumper I could put on with possibly adding a light weight wench to it? I just started my search and it's a tad overwhelming.
    thanks
  2. Aug 16, 2016 at 3:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Aug 16, 2016 at 3:37 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    All-Pro Aluminum bumper is probably your best bet. I have a bunch of All-Pro steel on my truck and the workmanship is amazing... I just wanted the heavy-ass steel version of it.
    I like my Wenches Light, but I like my Winches heavy... so you need to be more specific about what kind of Winch you want. If you're lookin' for wenches, though... you're gonna have to go to a different website.
  4. Aug 16, 2016 at 3:39 PM
    Pigpen
    Dan
    Northwest Montana
    I'm looking for a lightweight wench too...
    RacecarGuy likes this.
  5. Aug 16, 2016 at 3:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  6. Aug 16, 2016 at 3:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    For winch considerations, the Warn M8000 with synthetic line is good for a lighter winch, without going as expensive as the Warn 9.0RC, though not quite as powerful.
    Unchained 5150 likes this.
  7. Aug 16, 2016 at 3:50 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
