LightForce Help
Discussion in 'Lighting' started by Menametony, Oct 20, 2009.
  1. Oct 20, 2009 at 5:08 PM
    Menametony
    Menametony [OP] Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    ok.. i recently got some lightforce 240 blitz HID's... heres my problem, i installed everything i need to.. and i have a brown wire left over.. not exactly sure where this brown wire goes.. the instructions says something about a high beam and being "active" and i have to crimp.... but.. not exactly sure which wire.. i also have HID's... DSC_0083_943d438df1deaad7a6e3b71121da3e2d2f84888c.jpg
    any help would be nice.. thanks guys
  2. Oct 20, 2009 at 5:10 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    From what I see, there are 3 wires... correct? The red one with the fuse goes to the battery. The black gets grounded to the chassis. The brown wire should be the trip wire which you should tap into your high beams. This will trip the relay when the high beams are on and will also turn on your new lights.
  3. Oct 20, 2009 at 5:14 PM
    Menametony
    Tony
    Oahu
    tapping off of high beams... how exactly do i know which wire is the high beam? i mean would that prevent my lights not turning on? ive put everything together and tried turning it on without having the brown wire connected to anything and it doesnt turn on
  4. Oct 20, 2009 at 6:14 PM
    Menametony
    Tony
    Oahu
    bump for some help please
  5. Oct 20, 2009 at 6:21 PM
    Snyperx
    Snyperx Seniore Marcos
    When I installed my HElla 500's I used a multimeter to find out which wire off of the main headlight showed 12v. I touched the black probe to the chassis to make ground then used the red probe to check the wires with the hi-beams on. Does that make sense? Hope it helps.
  6. Oct 20, 2009 at 6:30 PM
    Menametony
    Tony
    Oahu
    yes it does.. i guess i have to go buy a multimeter...thank you
  7. Oct 20, 2009 at 6:34 PM
    Snyperx
    Good tool to have when doing electrical;)
  8. Oct 20, 2009 at 11:58 PM
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    If you unplug the headlight socket there will be three wires running to it. The tab closest to the center of the truck is high beam, I think its the yellow with pink, dont quote me.... but it is the inside wire out of the three
  9. Oct 21, 2009 at 10:41 AM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Or, you can buy a fuse tap and tap into where the high beam fuse is.
  10. Oct 21, 2009 at 12:41 PM
    TexasBlue
    TexasBlue Dreamer
    Kellan
    Dallas, TX
    07 PreRunner Sport, Speedway Blue
    Billet Grill, Roll-Top Cover, LED Interior Lights, HIDs, Foglight On Mod, Coin Tray Holster Mod
    Random side thought: Have you checked the amp draw of your lights when they're all burning? Looks like you've got a serious setup there, it might be time to think about bumping up the alternator, especially if you don't have the tow package.
  11. Oct 21, 2009 at 1:30 PM
    Menametony
    Tony
    Oahu
    I do have the tow package and just had the alternator replaced
  12. Oct 21, 2009 at 1:35 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Or you could get a test light and a friend and unplug your headlight harness. I did the same with my PIAA's but with the fogs. They shut off when i go to high beams(to stay legal) and only come on if the fog lamp switch is on(kinda like a master). Then i can turn my PIAA's on and off at will as long at the fogs are on. Sounds like the same thing but with high beams. Hope this helps
  13. Oct 21, 2009 at 3:51 PM
    Menametony
    Tony
    Oahu
    so i bought a multimeter.. found the wire that had 12v... tapped it in.. and put everything together and... it didnt work... meh.... i guess ill try to get this done at the URE meet... anyone want to help me?
  14. Oct 21, 2009 at 6:21 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    tapping into the high beams will only allow you to use the lights when your highs are on...If it were me I would want the option to be able to turn them on whenever I wanted to
    red wire=power
    black-ground
    get a fuse tap and run the brown wire to that, this will allow you to use whenever you want but will turn off when the truck is off
  15. Oct 21, 2009 at 6:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2
  16. Oct 21, 2009 at 7:24 PM
    Menametony
    Tony
    Oahu
    ill try this tomorrow... one thing, the switch.. does it matter which way i hook it up? where does the brown and red leads go?? the instruction says from right to left? man oh man..
    so just get a fuse tap.. maybe autozone / advanced auto parts might have.. tap it into the red wire from my HID's and viola?
  17. Oct 21, 2009 at 7:47 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    mmm not sure what is what on the switch, maybe someone can post a pic of the back of their switch with what is what.
    but the switch will have 3 prongs, one that will have a wire going to the fuse tap.
  18. Oct 21, 2009 at 7:59 PM
    Menametony
    Tony
    Oahu
    the switch that came with the relay only has 2 prongs....wtf?
  19. Oct 22, 2009 at 9:00 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    hmm, idk, i didnt run a realy for my lights. maybe someone can post a wiring diagram or you can search through the lighting forum for one, ive seem them posted on here before
    but I think one tab on the switch goes to bat. for power and other goes to relay power. not 100% though
  20. Oct 22, 2009 at 9:10 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Just for some reassurance, X4...
    I would NOT hook up my fogs/off-road lights relay signal to the high beam power. This will prevent you from using your lights when you would like to. Also, there is no need to spend the extra money on a DVOM. Spare your self the money and go get a 5 dollar test light from the auto parts store or wal-mart for that matter. Just find a positive power source that is always on when the key is in the ignition and you'll be good to go.
