lighting advice
Discussion in 'Lighting' started by pudge151, Aug 23, 2010.
  1. Aug 23, 2010 at 8:37 AM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i got some ebay style BHLM and as we know they are not the brightest and they dont have a great lighting pattern. well i am ok with that but am looking for a way to brighten things up a bit at night. they are great when on high beam but low beam just not so much. i have stock bulbs in there and clear laminex over them. i also have a satoshi grill. should i upgrade headlight bulbs, get off road lights behind the satoshi? HID is not possible as i wont spend the money on that. i just want a slight upgrade.
  2. Aug 23, 2010 at 9:14 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    wire harness and better bulbs. if you place lights behind the grill, they will be too high for fogs and driving lights are considered off road use only(most are anyways).
  3. Aug 23, 2010 at 11:07 AM
    pudge151
    Sean
    Connecticut
    what do you mean by wire harness?
  4. Aug 23, 2010 at 11:22 AM
    IamTacO
    adam
    QC az
    a wire harness goes in between your factory headlight plug and the bulb itself. it has a relay and is fed power directly from the battery. the theory behind this is that all wires have a certain resistance. it suppose to help be making the voltage drop less. less voltage equals less lumens for you headlights. other things also apply like the type of light bulb, how clear you headlight is(dirty, scratched), how they are aimed
    yes, the wire harness has resistance too
  5. Aug 23, 2010 at 1:05 PM
    pudge151
    Sean
    Connecticut
    cool thanks, maybe ill get some sylvania silver stars? or whaever they are called anda harness
  6. Aug 23, 2010 at 1:10 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I also have ebay BHLM's and they arent the greatest in output and patters like you said. I have HID's in them now and it helped but before that I had the Sylvania Ultra Silver stars or whatever they were called and they helped the output a lot!!
  7. Aug 23, 2010 at 1:57 PM
    IamTacO
    adam
    QC az
    There are better bulbs on the market than that. Search around before you buy
  8. Aug 23, 2010 at 8:02 PM
    pudge151
    Sean
    Connecticut
    any suggestions for better bulbs?
  9. Aug 23, 2010 at 8:16 PM
    IamTacO
    adam
    QC az
    check out this site http://www.suvlights.com/index.php?cPath=43
    you can find everything you should need here. it might be pricey, but at least you will know what to get. and i'm pretty sure that someone will pipe in with "you can get that cheaper somewhere else" if so, i hope they help you out too :)
  10. Aug 23, 2010 at 8:27 PM
    pudge151
    Sean
    Connecticut
    i will look at that site. i was just reading about the phillips extreme and the osram nightbreakers. they both seem to really hype up how great the hi beam is, but im looking for a better low beam, i hope your site helps
  11. Aug 23, 2010 at 9:21 PM
    IamTacO
    adam
    QC az
    i had bought a wire harness and some bulbs for my wrx from this website. i noticed a subtle difference when everything was in place. (polished headlights, new bulbs, wire harness)
