Lighting for Bed
Discussion in 'Lighting' started by mark1157, Mar 23, 2025.
  1. Mar 23, 2025 at 6:02 PM
    mark1157
    mark1157 [OP] Member
    I’m looking to add a light either LED or halogen to my tacomas bed that I can use to light up the bed or swivel it and light up whatever outside the bed.
    What are some suggestions for lights and what’s the best way to wire them?
    Mostly how should I run wire from the light to the inside of the cab for a switch? Thanks !
  2. Apr 2, 2025 at 9:32 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    There are different options for this. It really is going to be preference. Purchase a wiring harness kit for like fog/led strip lights. It'll come with a relay and all the necessary wiring to set it up. I mean you can hard wire it but I would suggest using a kit as it comes with a relay and fuse link. You can purchase one from Amazon but make sure you read reviews as some of these kits are made cheap.
    Regardless youll have to route the wires through the cab depending where you are mounting your switch. Below is an example of these kits. You might find other vendors with better quality kits. Good luck
    Amazon.com: Nilight - NI -WA 06 LED Light Bar Wiring Harness Kit - 2 Leads 12V On Off Switch Power Relay Blade Fuse for Off Road Lights Work Light, 2 Years Warranty,Black
    mark1157[OP] likes this.
  3. Apr 2, 2025 at 9:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    @mattgecko can fix you up with awesome LED under rail bed lighting
    Update your profile with info on your truck. At least year, trim and drive line. It will help when you ask future questions
    mark1157[OP] and mattgecko like this.
  4. Apr 4, 2025 at 6:49 AM
    mark1157
    How would you route it through the cab? I have a ‘22 SR access cab
  5. Apr 4, 2025 at 7:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    mark1157[QUOTED][OP] likes this.
  6. Apr 4, 2025 at 8:00 AM
    mark1157
    @mattgecko If your able to tell me where a hole is or something to feed wire into the cab from the bed that would help me a lot, thanks !
  7. Apr 4, 2025 at 8:12 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Would depend upon what Gen Tacoma your referring to but on my second gen behind the drivers side seat there's a plug in the floor you can run the wire through.
  8. Apr 4, 2025 at 8:54 AM
    mark1157
  9. Apr 4, 2025 at 9:57 AM
    mattgecko
    South San Jose, CA
    Probably the same place since 2nd and 3rd share the same cab.
  10. Apr 4, 2025 at 12:15 PM
    Toyoda213
    Jimmy
    SoCal
    lift the carpet up on the rear and youll see where some of the plugs are at. Pick one and route
  11. Apr 7, 2025 at 5:57 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    As you can see I have LED lights on my "roll Bar/ light bar" and I didn't want to drill any unnecessary holes. I used standard light kit as suggested above, and ran them into the engine bay(through the steering wheel gasket), as you be installing lights on the front. But I bought some extra lengths of the same gauge red & black wires that you would normal connect to your lights. Connected them to the wiring harness, with those extra long now, I ran them down underneath and (close the brake lines...then I ran it back up in between the bed and cab. I put it all in a wire loom and zip tied it securely. Had it that way for years with no issues. Or you can do a combination an utilize the hole/plug as others also described.
    I also used a Microtuning wiring kit from Ebay and its good quality.
    xBloodxLinex and Toyoda213 like this.
