Lighting Issue
Discussion in 'Lighting' started by TXFF41587, Oct 6, 2011.
  1. Oct 6, 2011 at 1:08 PM
    TXFF41587
    TXFF41587 [OP] Well-Known Member
    Tucker
    Santa Fe, TX
    07 TRD Prerunner
    I'm wiring some lights in to my bed and having some issues. I ran all the wires, mounted the lights, flipped the switch and got nothing. Tested the the main power from the battery and its good. Tested going strait from the battery to the light and still got nothing. This is my first time doing all this so any suggestions would help. Thanks
  2. Oct 6, 2011 at 1:31 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Check your ground?
    Is it wired with a relay or no?
  3. Oct 6, 2011 at 1:38 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    How are you 'testing' your wires. Theres a couple ways to test a system, like point to ground, wire to wire.... etc.
  4. Oct 6, 2011 at 1:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    check your grounds?
  5. Oct 6, 2011 at 3:36 PM
    TXFF41587
    Tucker
    Santa Fe, TX
    07 TRD Prerunner
    havent checked the grounds yet. will double check later tonight. I really hope it is the ground cause i had to cut a few times and really do not want to pull it back out to check them .
