Lighting Issues. Can you help?
Discussion in 'Lighting' started by 02sr5trd, Feb 4, 2012.
  1. Feb 4, 2012 at 6:51 AM
    02sr5trd
    02sr5trd [OP] Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    OK here is my problem. My dome light dose not come on when i remove my key from the ignition. It works fine with the doors and with the switch.I assume that it is probably a problem in my ignition switch but i was wondering if there are any other problem areas to look for. If it is the ignition switch is is just a replacement or a fix i can do? Thanks for any info!
    :headbang:TACOMA WORLD ROCKS:headbang:
  2. Feb 4, 2012 at 3:54 PM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Any help??
  3. Feb 4, 2012 at 5:19 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I can't even remember if mine come on when you turn off the truck and pull the key out. Are they supposed to? :)
    I doubt the ignition switch directly controls the lighting. Look at the wiring schematic, but if that function exists it is probably in the body computer--so I wouldn't just replace the switch. If the switch positions work (ACC, ON, Start, etc) then it's something else.
  4. Feb 4, 2012 at 5:21 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Get a multimeter or test light and check to see if you are getting power at the light then go from there.
  5. Feb 5, 2012 at 7:58 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    thanks guys. im pretty sure it has that feature iroc409, but now you got me thinking! i think it worked when i first got the truck. any one with a 1st gen able to confirm if it should come on when removing the key?
  6. Feb 5, 2012 at 8:47 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    If your truck is an 02, that function is controlled by the integration relay. If it is faulty, the cost to fix it would be waaaayyy more than its worth.
    AFAIK, It doesn't turn on until the doors are opened.
  7. Feb 5, 2012 at 9:34 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Thanks. It is a nice feature but if its costly I can live without it
  8. Feb 6, 2012 at 5:56 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you open the door with the key off, but still in the ignition, does the truck beep? There is a switch contact inside the ignition switch that tells the computer the key is in the ignition. If removing the key is supposed to trigger the dome light, and the switch is bad, that feature would stop working. I don't know what is normal behavior on a first gen. My second gen does not turn on the lights when I remove the key. I have to open the door.
  9. Feb 7, 2012 at 2:41 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Thanks, I will check to see if it beeps.
  10. Feb 19, 2012 at 12:26 PM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Well it dose ding like it should. I also know for sure that it dose have this option, it does work on a rare occasion. Any one else have an idea.
  11. Feb 23, 2012 at 4:54 PM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
